It all goes in tommorow....
Old 04-03-2009, 06:03 PM
  #81
Caveman1990's Avatar
I swear to God this damn build is cursed!! Cursed, I say cursed!! They finally got the car put back together and took it out for a test drive. About 10 minutes into the drive, the car dies and wont start, So after the car got towed back to the shop, they find out the ******* bearings are spun! They weren't even worn that damn much. Now the Crank has to be sent to the machine shop, and Im out a car for another week atleast. Damn this is ******* pissing me off!!!
Old 04-03-2009, 06:11 PM
  #82
ss.slp.ls1's Avatar
If you spun a bearing, you'll likely need an align hone of the mains and reconditioned rods too.
Old 04-03-2009, 06:20 PM
  #83
God damn it. This is going to be expensive as hell.
Old 04-03-2009, 06:22 PM
  #84
ss.slp.ls1's Avatar
If you spun a bearing, you'll know, your oil will be metallic and shiny. If so, I'd pull the engine and have the whole thing taken to a machine shop for a full rebuild.
Old 04-03-2009, 06:23 PM
  #85
Shop is closed for the weekend. I will call on Monday to see what are the deal is going to be.
Old 04-03-2009, 08:59 PM
  #86
Any ideas as to what would of caused this?
Old 04-04-2009, 12:26 PM
  #87
AZ2ENVY's Avatar
Where are you located in Colorado ? Spun bearings can be caused by a few
different things . Like debris falling into the motor during the build aka
(sloppy technician) , them spinning the **** out of the motor when they were test driving it are the two most common reasons bearings get spun .
Old 04-04-2009, 01:21 PM
  #88
My95Z's Avatar
I'd say the main/rod caps were not put back in their proper places or torqued correctly if it happened with that little mileage and the bearings were not worn much.
EDIT: Didn't realize it was a top end only job, sorry. Do you remember what your oil pressure looked like before it blew? They could have damaged the cam bearings on the install. Another reason it would do that was already mentioned above, over revving it, the rod bolts could have stretched and the bearing spun while this wouldn't show a lot of "wear" on the bearing like if it was old and worn out.
What bearings spun main or rod or both?
Old 04-04-2009, 07:54 PM
  #89
C5042081's Avatar
sorry to hear your problems, I always had the thought of my bottom end going, i opted to use the stock one when i did my H&C. Time to build it bigger and badder
Old 04-06-2009, 11:07 AM
  #90
I am from Crowley County. It was a main bearing that got spun. The people working on it at the shop said I shouldn't be worried about reconditioning the rods, but they are a little worried about the block. Oil pressure seemed fine actually, and we didnt even get on it too much on the test drive.
Old 04-06-2009, 12:20 PM
  #91
My95Z's Avatar
Thats odd to have the main's go, its normally the rod bearings on a stock LT1 shortblock...
Makes me wonder if something (debris) got dropped in the engine and plugged an oiling hole. Yea, the block will prolly need line honed now. Sorry to hear that man.
Old 04-06-2009, 12:41 PM
  #92
ss.slp.ls1's Avatar
There is no excuse in the world to not recondition the rods at the same time you are having your crank cut and polished and your mains align honed...none. You don't want to be dropping your engine in x months/years after spinning a rod bearing and do the whole rebuild all over again.
Old 04-06-2009, 12:49 PM
  #93
Ferg95 T/A's Avatar
Yeah I would put money on it that the shop did it. I have had the same thing happen to me twice...the shop(dealership) broke my car kept it for 6 weeks then made me pay over $3k to fix it...I sued them and I WON!!!!!!
Old 04-06-2009, 10:29 PM
  #94
The crank is scrap. The shop ordered a new one, and they are going to have to rods reconditioned and have the block inspected.
Old 04-07-2009, 02:32 AM
  #95
ss.slp.ls1's Avatar
If they are footing the bill, nice!
Old 04-07-2009, 08:01 PM
  #96
Right now the plan is to use a block form a 96 Cop Car. There shouldn't be any diffrences in the blocks, is there?
Old 04-07-2009, 08:04 PM
  #97
ss.slp.ls1's Avatar
No differences with the block. You might need to put a plug in the drivers side of the block because I think the '96 Bbody's have two knock sensors. Other than that, bolt on your top-end and accessories and you're golden.
Old 04-07-2009, 08:11 PM
  #98
Ok. They have the block out and are starting the rebuild
Old 04-07-2009, 09:02 PM
  #99
marc97taws6's Avatar
Hey, you got the bottem end going... now you are good to go man!
Lol wish I had the money to drop on that.. I am soon doing my conversion --- to a poor college kid .. haha
Old 04-07-2009, 10:37 PM
  #100
Haha thats the thing, I don't really have the money. I am in the same situation as you man, I just got some spare money left over cause Im going to college on a wrestling scholarship.
Quick Reply: It all goes in tommorow....
