95 vette cam only
My buddy has a 95 vette with a low mileage, stock motor. He has a few little things on it.
Muffler deletes
160 thermostat
SLP intake
tb airfoil crappy thing
He wants to go cam only on the car. No stall, gears, nitrous, or heads.
he has the performance gear ratio for the A4, I think 3.07 or something.
His car seems to be a very low 13 second car. He's looking for something that will not be too choppy, and have good power up to redline. Hoping to get his car around mid 12's. He's on somewhat of a budget so he doesnt want to do the LE1 or anything now. We were looking at maybe the CC503 w/ 1.6rr maybe?
Thanks guys,
Devon
Muffler deletes
160 thermostat
SLP intake
Thanks guys,
Devon
Comp ProMags 290
Patriot Spring kit 250
ARP head studs 38
TF guideplates 16
TF chromemoly pr's 87
Total: 981
That is with new parts. You can find used parts and save more money. Keep in mind that you have to buy intake manifold gaskets, timing cover gasket set, valve seals, and fluids. A mail order tune from MadTuner is 150. Will all said above, you can still get everything for under 1500. Also keep in mind, that the car might feel a little sluggish with stock manifolds, stock stall, and stock gears.
You will not need new pushrods with a low mileage motor as well as lifters
http://store.summitracing.com/partde...8&autoview=sku
I actually am using the Crane 10308 spring kit, but they are hard to find.
I would NEVER use stock pushrods with a CC503 cam and upgraded springs...
Stock lifters are fine.
https://ls1tech.com/forums/lt1-lt4-m...lp-needed.html
hmm.. This thread seems very familiar.
yeah, just looking around everywhere for him.
