Weld wheels backspacing for fbodies?
At minimum, you are going to have to grind your rears. If you have stock brakes up front, you shouldn't have to grind, but you will have to run a spacer iirc. If you have ls1 brakes up front, you will either have to grind a **** load, or grind a little bit and run a spacer.
i remember reading that those fit without grinding. oh well now i know. Quote: Originally by Smokinlt1
15x3.5s with 1.75 backspacing. My brake pads are low so I didn't have to grind the front or use spacers but when I do brakes soon I imagine I will have to grind the calipers a lil bit or use some universal spacers. 5/16th should be enough. On the rear are 15x8 with 5.5 backspacing that required a lot of grinding of the calipers( new pads). I'm using stock studs so I didn't want to chance it using spacers.
Idk why you'd run em all the way around, but I was looking at those wheels and was wondering if they would fit.. hmm
