Weld wheels backspacing for fbodies?
Old Mar 3, 2009 | 11:05 PM
1badzee's Avatar
Default Weld wheels backspacing for fbodies?
Whats the backspacing for our cars for an 8in wheel and for a 10in? (15x8 and15x10)
Also, what's our bolt pattern? =P
much appreciated
Old Mar 3, 2009 | 11:06 PM
danhr's Avatar
u'd think with > 1,000 posts that you would have figured out the search function by now.
Old Mar 3, 2009 | 11:10 PM
myltwon's Avatar
5.5 for 15x8 and 7.5 for 15x10
just going off memory though so I could be wrong
Old Mar 3, 2009 | 11:11 PM
1badzee's Avatar
searched and nothing came up. care to help?
Old Mar 3, 2009 | 11:12 PM
creepingdeath94's Avatar
The search is not working properly. Every time I use it it brings up everything and anything but what I typed in...and I have tried various ways, combinations, etc. to no avail. So it probably isn't his fault that the search came up dry...
Old Mar 3, 2009 | 11:13 PM
fergymoto's Avatar
mylt1won is correct.
Old Mar 3, 2009 | 11:17 PM
robsquikz28's Avatar
true that the search sections suck *** now something is wrong
MODS PLEASE FIX THE SEARCH SECTION, THANKS
Old Mar 3, 2009 | 11:20 PM
1badzee's Avatar
What about the front ones?
 Michael S. Palmer
Old Mar 4, 2009 | 06:06 AM
daves94formula's Avatar
most guys run the 1.75 BS on like a 15x4
Old Mar 4, 2009 | 07:37 AM
BlackTA96's Avatar
Bolt pattern is a 5x4.75"
Old Mar 4, 2009 | 08:32 AM
1badzee's Avatar
Much appreciated guys!
Old Mar 4, 2009 | 08:41 AM
xx_ED_xx's Avatar
Agreed. it is actually easier if you know the name of who posted something about what you are looking for. then the actual subject content
Old Mar 4, 2009 | 08:47 AM
1badzee's Avatar
Has aynone ran a 4.75 backspacing on a 15x8? Would it stick out too much?
Old Mar 4, 2009 | 09:14 AM
BlackTA96's Avatar
Never heard of a 4.75 backspacing.
I've heard of a 4.5, and yea that'll stick bout an inch or so out of the fender.
Old Mar 4, 2009 | 02:53 PM
Smokinlt1's Avatar
5.5 on my 15x8s and 1.75 on the 15x3.5, pic in sig
Old Mar 4, 2009 | 03:28 PM
C5042081's Avatar
15x8 with a 5.5 bs is close to factory as far as sticking out
Old Mar 4, 2009 | 04:10 PM
C_Rules's Avatar
do some weld wheels require grinding even with the proper backspaces. i know the ones smokinlt1 has fit with no grinding.
Old Mar 4, 2009 | 05:58 PM
danhr's Avatar
they require grinding, even the ones that smokinlt1 has you have to grind.
At minimum, you are going to have to grind your rears. If you have stock brakes up front, you shouldn't have to grind, but you will have to run a spacer iirc. If you have ls1 brakes up front, you will either have to grind a **** load, or grind a little bit and run a spacer.
Old Mar 4, 2009 | 06:06 PM
C5042081's Avatar
longer studs are recommeded if you use spacers
i know its for ls1 but it give you an idea
http://www.freewebs.com/casper9t9/dragwheelinfo.htm
Old Mar 4, 2009 | 06:18 PM
LT1's Avatar
LT1
Bolt circle for the Weld rim is 4.75 inch
If you get 15X3.5 the backspacing is 1.75
You will have to grind down caliper cooling fin weather you use spacer or not. If you use spacer you grind less.
The brake pad thickness has a affect on the position of the caliper suggest replaceing the pads when you do the clearanceing.
I recommend getting ARP wheel studs 12mm X 1.5, 3.25"
http://www.thunderracing.com/catalog...vid=4&pcid=148
I had to get shank style lug nuts 12mm x 1.50 RH they come in open end and close end to run on the track you need open end.
