Vibration after Wheel Hop
Old 03-07-2009, 12:51 PM
fasttransamlt1's Avatar
Default Vibration after Wheel Hop
I took my car to the track last sunday and when the car leaves I had a real bad wheel hopping problem. After I left the track driving the car home there was a very bad vibration coming from the rear of the car. It only happens around 30 mph up to about 70 mph....Any help would be great..... I have checked the drive shaft it looks ok. PLEASE HELP
Old 03-07-2009, 01:14 PM
lifeisgood's Avatar
wheel hop is caused by the lower control arm bushings being worn out.
and if you completely screwed them up, id say thats your problem
Old 03-07-2009, 02:16 PM
Do you think that the LCA bushings is what is causing the vibraton??
Old 03-07-2009, 02:55 PM
lifeisgood's Avatar
yes look into it. see how bad they are
Old 03-07-2009, 03:13 PM
thanks for your help.....
Old 03-07-2009, 03:43 PM
lifeisgood's Avatar
if thats not it, i could see maybe a axle bent from the hopping but that may be a stretch.
that or driveshaft.
i really doubt that its a tire that through a weight but guess that also could be a option
Old 03-08-2009, 09:53 AM
FASTFATBOY's Avatar
Mine did that and it spun the wheels inside the tire, this threw the tire balance completely off. I chased it for weeks. Balanced the rear tires, fixed.
Old 03-08-2009, 11:36 AM
lifeisgood's Avatar
i had a tire spin but it broke the bead and lost air pressure
Old 03-09-2009, 06:26 AM
95greenmaro's Avatar
narrowed the problem down to the drivetrain. Replaced u-joints and bushing in tailshaft, pulled out the axles and checked them, and also checked the motor mounts. The vibration is felt at too low of a speed to be the tires out of balance. Any more suggestions? The vibration is felt in low rpm's all the way up to higher rpms's.
Quick Reply: Vibration after Wheel Hop
