finally my build thread!!
Old Jun 21, 2009 | 06:57 AM
  #81
z28rob18's Avatar
here's all the stuff i cut out maybe 3lbs worth not much but it adds up
Old Jun 22, 2009 | 04:20 PM
  #82
z28rob18's Avatar
the heads came!!!!!!!!!!!!!!! im excited as hell lol the are beautiful. now i just need a motor to put them on lol. the axels were also fixed today i picked them up. here's the pics the ones flow #s
Old Jul 4, 2009 | 07:46 AM
  #83
z28rob18's Avatar
well after a very late and difficult night the rear is in the car and most of the suspensions on. sway bars off and the tq arm needs new bolts were it mounts on the chassis. we completly did it wrong twice first time we put the springs in and jacked it up tryin to mount the shocks. it took a 2' tumble off the jack. second time we put the lca's on and jacked it up it helped but forgot the tq arm and made it a pain at the end. another problem was missing bolts. either mice are walkin off with them or my friend that helped take it apart didnt put them where they should be. but its in here's a few pics.
Old Jul 7, 2009 | 06:30 AM
  #84
z28rob18's Avatar
hung the sway bar last night and check the wheel fitment over the new brakes. the greg welds barely fit over just the rotors and the jegs stars barely hit the calipers. so i need a new set of street wheels. forgot to take a pic of the sway bar finished hangin on the rear so here's the one pic i got.
Old Jul 8, 2009 | 04:35 PM
  #85
Rich2279's Avatar
Looking good, Rob. Nice build up you have going.
Old Jul 9, 2009 | 06:32 AM
  #86
z28rob18's Avatar
thanks man
well guys one of the coolest things so far on the build was started last night. our one friend backed out but my dad had another who really really knows transmissions. so we cracked open the trans and he started to rebuild it. got it all apart we stopped because i need to get new blocker rings. but after we took it apart he actually took time to explain some things said it was one of the easiest trans' hes ever taken apart. also said it was real clean inside with not much wear if any.he'll be back sunday to finish it. here's a few pics i took.
Old Jul 11, 2009 | 12:31 PM
  #87
z28rob18's Avatar
well today has been AWESOME!!!! one of the best days of this build. we took a ride to the machine shop and picked it all up. it is sweet! have tons of boxes of parts from them and a ton of picks. also had carbon fiber blocker ring kit overnighted so the trans can be finished tomorrow. but the motor should get build this week. and possibly be between the framerails. but i go away on vaca for a week startin the 18th which i was lookin forward to but not anymore since ill be so close to gettin it done. well here's a bunch of pics.
Old Jul 11, 2009 | 12:40 PM
  #88
z28rob18's Avatar
messed up. forgot these
Old Jul 16, 2009 | 06:30 AM
  #89
z28rob18's Avatar
well trans is done. went together pretty easy i could never do it but it was cool to see. i also cleaned every part i could find. while i cleaned my dad finished the rear brakes ebrakes and all. i had a pic but i must of deleted it. sucks that i leave for a week vaca saturday right when things get good
Old Jul 29, 2009 | 06:51 AM
  #90
z28rob18's Avatar
so all the oiler rings are filed and fit. and half the compression rings are. these rings take time and hurt your hand lol
Old Jul 29, 2009 | 08:42 AM
  #91
Whyrun's Avatar
Glad to see it's all coming together. It's a slow process but take your time it will be worth it ..
Old Jul 31, 2009 | 06:28 AM
  #92
z28rob18's Avatar
yea ive found out it takes time well all 40 (i think thats all) rings are ground and set right. my hands hurt from it but it was new to me and cool. next idk lol i suppose put the rings on the pistons and rods on pistons
Old Jul 31, 2009 | 10:45 AM
  #93
fast93z28's Avatar
love this thread lol
Old Aug 6, 2009 | 04:17 PM
  #94
z28rob18's Avatar
so ive been away again but stopped home yesterday and we got the bearings in set the crank in plastic gauged it then torqued down the main caps. we also got a rod put onto a piston. damn spiral locks r difficult.
Old Aug 6, 2009 | 04:29 PM
  #95
z28rob18's Avatar
also forgot to mention i got this package before leaving
Old Aug 8, 2009 | 05:20 PM
  #96
RacerXLs1's Avatar
any updates...
Old Aug 8, 2009 | 08:01 PM
  #97
z28rob18's Avatar
no. hopefully tomorrow's eventful
Old Aug 10, 2009 | 06:40 AM
  #98
z28rob18's Avatar
well got some well i think alot done last night not as much as i wanted to yesterday though because of some college shopping. we brought the rods and pistons inside and installed all the spiralox we thought that they'd take all night but turn out simple. then we got all the rings on the pistons. fixed our oil ring problem they didnt sit right thats because the diamond pistons came with a ring for the oil groove to fill space. so tonight they go into the block and the cam might too. i got some pics of my dad puttin the spiralox and rings on because i got a new phone.
Old Aug 11, 2009 | 06:39 AM
  #99
z28rob18's Avatar
well last night went well. hit one bump in the road but cruised the rest of the way. we hav a short block. pistons r in rod bolts reclearanced and torqued the cam is in and degreed the whole timing chain set up is on as well. the one thing that we had a problem with is the rods needed to be spun around because there's a thicker side and we had it facing wrong. so here's the pics i took throughout the night. tonight we'll get some play doe and check the valve clearance
Old Aug 11, 2009 | 11:55 AM
  #100
Driftunit's Avatar
you should start direct linking your pics via photo bucket or something. anyways great build, i cant wait to start mine!
