I know nothing of emisions...
heres the ones I found:
http://www.randdspeed.com/index.php?...roducts_id=243
The AIR fittings included in the kit are for the exhaust manifolds. Remove the AIR pump and all of the lines attached to it. You'll see that there is a fitting on the top of each exhaust manifold - remove the pipes going into them. That's where the plugs go.
wicked94z...whats that second pic? is that the exhuast hose?
I found this for !EGR. It looks fairly straight forward...
http://shbox.com/1/egr1.jpg
What about AIR? Where is the AIR pump?
I know I need to get it tuned out later too...
The AIR pump is located on the driver side front of the engine, just below the coil, and to the right of the water pump, and is held in place by three bolts. To remove it, you just remove everything attached to it. There are several pipes and hoses that come off of it. You'll need to plug the hole in the intake ducting and cap off the fittings in both exhaust manifolds, using M18 plugs. Have the AIR pump programmed out and enjoy a cleaner engine bay.
Is there an AIR pump fuse I should remove or will getting it tuned out take care of it?
I got a friend
Anyway, it seems very easy. Hopefully those headers get here soon. theyre on back order right now and probably won't get here untill next week. I'll post up pics and questions if I have any while Im doing it.
Thanks for your info guys.
