Speed Inc's Hid kit
Old 09-18-2009, 12:36 AM
SoxXpupPeT's Avatar
Default Speed Inc's Hid kit
after driving the car for a year with POS headlights i finally got sick and tired enough to do something about it. i searched and found that speed inc sells a full bolt in HID kit for all f-bodies. for $200 shipped with replacement housings i took it as a deal.
the install was very straight forward and very simple. just remove the old housings, and then install the new ones along with mount up the ballast.
new vs old
you can see where i had mounted the ballast right behind the high beams
in conclusion anyone that has an F-body should Seriously look into this kit or kits that are similar. the difference on the road is amazing i can actually see whats ahead of me! its in my top 5 must do mods to an f body thats for sure. if their is one thing i can nit pick about its that where you hook up the ballast to the light plug. the cables were backwards and the negative went tot he postive and vis versa. i just simple reversed the plug and all was good.
Old 09-18-2009, 12:39 AM
OlMastaScrilla's Avatar
Sweet, I was thinking about doing this but now im sold on it. very nice
Old 09-18-2009, 01:48 AM
DopdBrd's Avatar
Did it on my Firebird awhile back. I only drove it a few times in the dark before I pulled the motor but they are 10X better than the factory ones.
The fiancee has some on her car and I am going to put some on my truck.
Old 09-18-2009, 01:49 AM
marc97taws6's Avatar
Hmm do they have these for my Trans Am? lol my little thing is broken off so my high beams don't work.. maybe this will be my solution
Old 09-18-2009, 07:02 AM
SoxXpupPeT's Avatar
yes they do,
http://www.speedinc.com/catagory.cfm?catagory=Lighting
just specify it when you order them.
they are a must have for anyone that doesnt have HID's already! thanks tony for the feedback again!
Old 09-18-2009, 11:23 AM
kinglt-1's Avatar
There was a thread on this a couple weeks ago. You can modify the stock housings by heating up the glue that holds the bulb in. Remove it and rtv the new bulbs in. You can get the 9006 hid kit for 65.00 shipped on ebay and save yourself 135.00
https://ls1tech.com/forums/lt1-lt4-m...light-kit.html
Old 09-18-2009, 11:33 AM
nomoneyz's Avatar
Exactly. Mine cost me something like 62.00 shipped. And they are amazing.
Old 09-18-2009, 12:16 PM
LS1 SPEED's Avatar
We appreciate the order and positive feedback on this product. There are many kits out there and we tried a few on our personal cars before chosing these. We have had 0 issues and it's a nice simple bolt in / clip in deal.
I have the housing already with just upgraded bulbs, but will be doing this kit soon so I can see at night.
Old 09-18-2009, 12:43 PM
riceburnerZ28's Avatar
they look great! I'm sick of driving around with my high beams all the time!
Old 09-18-2009, 12:55 PM
Lizard King's Avatar
I don't see an option for light output. Is 4300k available?
Old 09-18-2009, 01:22 PM
SoxXpupPeT's Avatar
i woulda done that but my housings as you can see from the first pic are in bad shape. they had chips and the reflector was actually missing in spots. so i saw the kit as really being worth it
anytime! it couldnt of been easier to install. it was very nice and simple. the only thing however was that the clip that connects to the stock wiring harness for the power. the leads were backwards when you put the clip in the correct position. the positive of one went to the negative and vis versa.
Old 09-18-2009, 02:53 PM
James Montigny's Avatar
The big issue I see with those kids is that the housings were never designed
to handle that type of bulb. It's not an issue of the amount of light, it's the
focus and proper shape of what is emitted.
Old 09-18-2009, 03:23 PM
94Z28rag's Avatar
Paid $50 shipped for mine. You guys are crazy spending that much.
Old 09-18-2009, 05:45 PM
kinglt-1's Avatar
right, but the speed inc kit looks like a modified stock housing to me. So your not gaining anything unless your old housings are cloudy. might as well just modify the stockers if they are in decent shape.
Old 09-18-2009, 10:50 PM
bowtie_racer's Avatar
I used a 9006 kit I had previously on my truck, I didnt even have to heat up the glue. Just pryed up on the original bulb with hardly any pressure and it popped right out! Heres a few pics.
Attached Thumbnails Speed Inc's Hid kit-8-9-09-001.jpg   Speed Inc's Hid kit-j.p.-stuff-007.jpg   Speed Inc's Hid kit-j.p.-stuff-008.jpg
Old 09-19-2009, 01:08 AM
White97z28's Avatar
Just got a kit today on ebay, 9006's 6000k, 45 shipped to my door.
I'll let you know how it is when it shows up..
Old 09-19-2009, 02:03 AM
1badzee's Avatar
I regret selling my HID's.. I seriously can't see **** at night. I'm buying some more soon.
Old 09-19-2009, 11:03 AM
kinglt-1's Avatar
You should of got the 35w digital slimballast for a little more. The 55w analogs run super hot and need to be ran on seperate power wires, not the factory wiring like you can do with the digital 35w.
Old 09-22-2009, 05:07 PM
litch2004's Avatar
they have them for every application except mine. My car has a 98 front end upgrade and for some reason they skip that year.
Old 09-22-2009, 05:42 PM
DopdBrd's Avatar
Exactly. They don't make a housing that has a "TRUE" projector in it. I bought a cheap set of housings off Ebay that are supposed to be "projector" housings but they are not true ones. They work good and focus the light better than just a halogen housing, but I would much rather have a true projector.
Quick Reply: Speed Inc's Hid kit
