Need help converter selection
Old Mar 26, 2009 | 10:23 PM
Red93z28's Avatar
Default Need help converter selection
Hey guys i need some help, right now i have a 2600-2800 stall from peformabuilt, i need more for this car, cam has 5.76 and .570 lift with 230 and 236 duration with ported heads and bigger valves, everything else is in the sig, any suggestions, what stall and company, any bargains out there, thanks guys really appreciate it
Old Mar 27, 2009 | 09:55 AM
vanilla89's Avatar
Most people on this site will say yank, they make a great converter. I have had two, but I just ordered a Circle D +4c it's a 4200 stall and I recomend you you check them out.
Anyone of the sponsers make a great converter the hard part is picking who...
Old Mar 27, 2009 | 12:28 PM
Red93z28's Avatar
thanks for the advice, anybody got any other ideas??
Old Mar 27, 2009 | 02:00 PM
ss.slp.ls1's Avatar
Yank SS3600.
Old Mar 27, 2009 | 02:05 PM
monster81's Avatar
anyone running TCI, is it any good?
Old Mar 27, 2009 | 02:07 PM
marc97taws6's Avatar
From what I hear, TCI is generally more of a budget converter.. and you get what you pay for
Old Mar 27, 2009 | 02:08 PM
TABBED 5.3's Avatar
I have a 3500 TCI in mine, no problems with it. works great off the line, probably not the most efficient on the top end though.
Old Mar 27, 2009 | 02:12 PM
Top end power is always good too
It's up to you, OP, to each is ones own
Old Mar 27, 2009 | 07:55 PM
StealthFormula's Avatar
What rpm do you shift at? What gears does the car have? Is the car a DD or Weekend Warrior? Any plans for adding N20?
In terms of all motor your going to want something that has a shift extension about 800-1000rpm below your shiftpoint. In terms of stall speed I would suggest 3600-4000.
I use to run the Yank SS3600 and I loved it. However it had a 4900rpm shift extension which is less than ideal with a car turning 6400rpm. Its currently being restalled to the PT4000. The PT series from Yank are designed for max effort N/A applications. The shift extension on the PT4000 with my power level and 3.73's is ~5600. Unsure about your gearing but your power level is similar to mine. I would recommend the SS4000 or PT4000 to you if the car is not a DD. If its a DD I would probaly go with the SS3600 which I DD'd myself and enjoyed. Anything larger than that might be too "loose" for DD'ing.
I would call up Dave at Yank and see what he says. Also maybe call up Chris at Circle D, they seem to be making some real quality converters that perform great just like the Yanks.
