Engine Rebuild (pics)
Old Mar 31, 2009 | 11:21 PM
SoxXpupPeT's Avatar
Originally Posted by ThoR294
so you pulled it from the top? was it easy?
with no tranny and the bracket i made... a piece of cake it would of been even easier without the balancer. sure i had to remove everything but i perfer doing it like that.
Old Apr 1, 2009 | 06:11 AM
GIZMO's Avatar
Originally Posted by SoxXpupPeT
I really don't think that there is much advantage in running a four relief piston with stock style reliefs. I would look for something with two reliefs. That way you won't have to worry if you want to upgrade the cam later. I still think that forged rods would be a worthwhile upgrade if you plan to go faster later.
Old Apr 1, 2009 | 08:57 AM
sweet-94z28's Avatar
Sounds similar to what I am doing right now. I bought a super low mile shortblock and I am going through it. I reused the entire bottom end (only had 32K miles anyway) and I'm just installing clevite bearings, total seal rings and some ARP hardware. I can't wait to see what yours ends up like too!
Old Apr 1, 2009 | 04:42 PM
SoxXpupPeT's Avatar
ive been thinking about just keepnig the stock pistons for now too. because i dotnw ant to shell out alot of money for pistons or rods if i build up a 383 over the winter or next spring/summer. or if i decide to build up an engine thats for.... some force feeding
ill probably be doing that. just replace everything that needs to be replaced and keep whatever i can. i plan on building up an engine in a year or two and i dont see the reason in spending so much on an engine thatll probably only see 400 hp with no spray.
Old Apr 2, 2009 | 06:28 PM
SoxXpupPeT's Avatar
Default New parts!
i got my cylinder heads back from the machine shop stripped down and semi clean. ive decided im going to do a gasket match to them. there horrible! i cant believe how off the they are from the gaskets! here are some pics showing the heads along with my new parts! alot of ARP bolts and studs, and of course my comp cams gold rockers!
new parts!
Here are my new comp cams 1.6 NSA 7/16 rockers vs PRW's 1.6 3/8 SA rockers
there both really nice pieces. but the comp cams feel so much smoother then the PRW's. over all tho for the price the PRW's are very hard to beat. they are of course heavier then the wide bodied forged aluminum comps but some im sure see that as not being a big enough problem to not spend the extra money on the comps. i however dont wish to spend more money later on rockers again like ive done before.. i dont doubt the PRW's but i feel more secure with the comps. i dont really want to sell the PRW's even tho i dont need them anymore. there really nice pieces :p
Old Apr 2, 2009 | 06:34 PM
ss.slp.ls1's Avatar
new parts!
Nice man, nothing better than looking at new pieces out of the box before they go in. Are you going to gasket match the intake as well?
Old Apr 2, 2009 | 07:02 PM
My95Z's Avatar
PRW's are nice pieces for the price!
I'll try to find you a good article on gasket matching b/c if you remove all the material to gasket match you'll actually hurt airflow.
Gotta love new parts, its like Christmas! lol
Old Apr 2, 2009 | 07:30 PM
GIZMO's Avatar
If you are going to do anything, do a little bowl work right below the seat. I would not gasket match. If you don't have one, find a 1997 intake (you will see why right away).
Old Apr 2, 2009 | 09:53 PM
SoxXpupPeT's Avatar
the intake i already gasket matched. i only opened up the very end and just smoothed everything else out. with the heads ill just be smoothing out the rough edge off the face. its creating to much turbulence like that.
they really are nice for the price. i somehow came up with a good enough reason to spend the extra money for the comp cams. next time ill def use the RPW's
id appreciate it if you could find a good article. im not going to to to crazy with it. i just want to smooth it out as much as possible.
i dont have a 97 intake. just 2 94 intakes. i cleaned only the end. this is the best pic i could find of when i did it
Old Apr 3, 2009 | 03:04 PM
MTBSully's Avatar
how could gasket maching hurt airflow?
Old Apr 3, 2009 | 05:04 PM
SoxXpupPeT's Avatar
if you make the intake runners to big and no step in it then the velocity wont be high enough for it to work properly
Old Apr 6, 2009 | 01:26 PM
  #32
SoxXpupPeT's Avatar
Just alittle update on whats going on. i talked with the builder today and were going to bore the block .030" and go with forged speed pro pistons. reusing my connecting rods and having my crank cut and polished. im also in the process of gasket matching my heads and i must say the exhaust side is coming out rather nicely. ill post pictures later tonight when i get home. i cant wait till its back together!
Old Apr 6, 2009 | 01:32 PM
  #33
ss.slp.ls1's Avatar
Cool, awaiting pics.
Old Apr 6, 2009 | 06:18 PM
  #34
SoxXpupPeT's Avatar
Default more pics
as i said. here are some more pics of my build
head parts
stock crank ready to be cut and polished
this is the water pump drive with a nice groove in it from the seal
i couldnt seem to find a new one so i figured id repair it
all clean
stock exhaust ports with my felpro copper gaskets. the gaskets match up next to perfect on my mac mid headers so i figured id take the opportunity while the heads are bare to open them up abit
took out alot of material but made sure to keep everything as smooth as possible
now thats more like it!
and with alittle bowl work aswell.
i know i should do alittle more bowl work but i dont want to **** anything up to badly. i think how i have them now is pretty damn good. the exhaust is going to flow so much more smoothly out of the cylinder. i have to finish up the bowl area on the driver side head alittle more tomorrow before i move onto the intake side.. im kinda nervous about that but i dont plan on taking to much off. ill see how it works
Old Apr 6, 2009 | 06:23 PM
  #35
ss.slp.ls1's Avatar
head parts
all clean
Looks like you are doing a sweet job man. Nice work with the water pump shaft! I wish I could weld and had access to precision tools.
Heads are coming along nicely, even though is small gains, every little bit counts, good thing you are being conservative and not trashing a set of heads.
Old Apr 6, 2009 | 06:29 PM
  #36
SoxXpupPeT's Avatar
thanks alot man! ive only been welding for about a year or so. it all depends on how badly you want to know how to do it. thats what im overly concerned about with my heads. i really really Really dont want to **** them up. but as you said every little bit counts so im hoping alittle bit here and alittle bit there will add up to some nice numbers when i get it all back together. im going to be boring the block .030" with forged fel prop pistons. my builder is getting a helluva price on them. the more time passes the antsier i get to finish it up and unleash the boat anchor fury!
Old Apr 6, 2009 | 09:54 PM
  #37
YngBird's Avatar
wow man, you are doing a great job. i cant wait to tear into mine.
nice work on the shaft also.
Old Apr 6, 2009 | 10:45 PM
  #38
SoxXpupPeT's Avatar
thanks man! ive learned alot at my shop. the head porting is just ALOT of patience and a steady hand lol i hope to finish the exhaust at the very least this week and start on the intake. im hoping end of next week the engine will be back together.
Old Apr 8, 2009 | 12:23 AM
  #39
JayplaySS's Avatar
Moderator
Nice work
Old Apr 12, 2009 | 02:58 AM
  #40
SoxXpupPeT's Avatar
Default lil update
Originally Posted by JayplaySS2
Nice work
ty ty
ive been really busy lately and havent updated this in awhile as a result of that. progress on the build has been steady. monday my pistons and all bearings along with the oil pump get ordered through my builder. theyll be in around thursday and around friday or next monday of next week my crank will be but and polished and my block will be bored .030" over and honed. and somewhere inbetween all this chaos my heads will be decked, cleaned, and assembled with my old valvetrain.
before and after of my intake runners being gasket matched
