Ebay Opti?
Old Mar 31, 2009 | 02:12 PM
Green3spd's Avatar
Default Ebay Opti?
I know this has been discussed before but I didnt find anything...
What do you think about it?
Having a high RPM misfire when car is heat soaked and everything else I can think of is fairly new...
Should I replace the Whole Opti or just Cap N Rotor?
Old Mar 31, 2009 | 02:34 PM
stealth_bird_346's Avatar
First I would check each wire,plugs,then coil.<---(@Night) If you do decide to change the opti make sure it's an a/c delco made in USA. Big brther went through 3 in 1yr. Goodluck
Old Mar 31, 2009 | 02:37 PM
shbox's Avatar
Are we supposed to be looking at something in particular?
Old Mar 31, 2009 | 04:31 PM
Green3spd's Avatar
Lol.. well no, there is several of them and just a couple are ACDelco at $345 and several just over $100
Old Mar 31, 2009 | 04:32 PM
Green3spd's Avatar
Ive tried two seperate coils and it only does it when the car sit for awhile OR if Im doing in-town driving... if I jump on hwy it cools off and runs fine..
Old Mar 31, 2009 | 05:26 PM
ss.slp.ls1's Avatar
The only one you need to consider is a genuine AC Delco/Delphi opti from "thepartsladi" on ebay.
Old Mar 31, 2009 | 09:52 PM
shbox's Avatar
Something on Ebay could come from anywhere. Ebay is not a brand name.
Old Apr 1, 2009 | 09:02 AM
Green3spd's Avatar
Ive also looked into Coil packs... Where is the cheapest place I can pick up the conversion? Ive looked and only found one place and it was a bit pricey..
Old Apr 1, 2009 | 09:05 AM
Purple95Z28's Avatar
Which one on ebay did you buy? I have a Delphi one from "thepartsladi" and it spins to 6600rpm without problems.
Old Apr 1, 2009 | 11:05 AM
ss.slp.ls1's Avatar
Waste of money IMO.
Old Apr 1, 2009 | 01:08 PM
Elliott's94Z's Avatar
+1...watch out for any other company on ebay other then thepartsladi. I got schooled a while back by a company on there and ended up buying a opti that ended up not being what they said it was.
Old Apr 1, 2009 | 03:14 PM
Green3spd's Avatar
Ill look for her then.. thnks
Old Apr 1, 2009 | 05:09 PM
ss.slp.ls1's Avatar
Look no further:
http://cgi.ebay.com/ebaymotors/95-96...mZ390040905006
Old Apr 1, 2009 | 06:10 PM
Green3spd's Avatar
Awesome! Thnks!
I'm replacing an O2 sensor today/tomorrow, if that doesn't fix it I'm goin after opti!
