High vlm oil pump ?
Old Apr 4, 2009 | 09:05 AM
shbox's Avatar
Originally Posted by SoxXpupPeT
hmm its a GM part so itll be pretty good. looks like a good quality piece aswell. but theirs only so much looking you can do for a picture :p ill take it the pick up tube on that is .750 aswell ?
Not sure that is a 3/4 inlet. It might also be the weaker casting.
Better to go with this suggestion:
Originally Posted by Elliott's94Z
Melling Select 10554
Melling Shaft IS-55E
GM White Spring 3848911
GM pickup tube 12550042
Old Apr 4, 2009 | 09:18 AM
96capricemgr's Avatar
"How?" and "Why?" Are the two most important questions anyone can ask about anything, but rarely are asked and even more rare is for them to be intelligently answered.
Once you understand the system you wont need to come here and ask folks without a clue what their completely unfounded opinions are.
I see a lot of bad builders spec HV pumps because they don't take the time and effort and use good parts to set the engine up tight. Easier to slap it together halfassed use a HV pump and thick oil.
Old Apr 4, 2009 | 09:27 AM
Z8'S's Avatar
So ......only half-assed builds require HV oilpumps?
Old Apr 4, 2009 | 10:06 AM
SoxXpupPeT's Avatar
this is why i rely heavily on this forum to give me a better understanding and pov of certain situations. without people as involved as you and others on this forum and other such forumsalot of people would be lost. such as myself
Old Apr 4, 2009 | 10:30 AM
I am not saying a HV pump is proof of a bad build, I am saying HV pumps are popular with halfassed builds. Use cheap components with huge tolerance issues and such and it is easier to slap it together loose and rely on HV and thick oil.
Like I said look into "How and why?"
How does the oiling system function and why do you want or need more pressure of volume?
As shbox said too many guys have destroyed oilpump drives too.
Old Apr 4, 2009 | 01:38 PM
bombebomb's Avatar
thanks guys. i just dont want to tell the guy thats building my engine what not to do. but i also dont want to **** up anything
I told my builder everything I wanted, and if he disagreed we discussed why etc. Most of the time I went with what I wanted. Sometimes two opinions are nice but if you do not want something done make it clear.
Old Apr 4, 2009 | 02:00 PM
Z8'S's Avatar
A good write on how and why........... Instead of talking down to someone I did not write this but do follow this belief.
In the case of engine oil pumps pressure and volume are related.
The engine is a controlled oil leak, the pump cannot develop any pressure until the volume it's putting out exceeds the volume that can leak thru the clearances. To get more pressure, it has to deliver more volume. Ultimately pressure is controlled by the volume leak past clearances and the a "relief valve". The relief valve adds to the leakage past the clearances thus maintaining a certain pressure.
Pressure is variable to the viscosity (weight) of oil used, the temperature of the oil, and the speed of the pump. Starting backwards, at idle the pump is turning slowly and pressure will be less, so much so, that when the engine is hot the relief valve is probably closed and pressure is simply established by the leakage thru the clearances. Conversely, at high speed the pressure increases because the pump is pushing more oil (volume) into the engine. At some point the volume/pressure will exceed the relief valve's spring and it will be pushed open reducing system volume and pressure. This is also affected by the thickness of the oil. Cold oil of any given "weight" has more viscosity or thickness than when hot. The thickness of the oil determines how fast both the pump can pick it out of the pan and how fast it leaks past the clearances. Thick oil results in abnormally high pressure at the pump which causes the relief valve to open. As the oil heats, it becomes thinner which is easier for the pump to pick out of the pan and it leaks faster thru the clearances. This reduces pressure and it's highly likely that the pressure relief valve will close. The same thing happens for the weight of oil in regard to leakage past the clearances and the setting of the pressure relief valve. All these variables occur at the same time.
Note that the relationship of pressure and volume is different in an engine than in a closed hydraulic system, because an engine constantly leaks oil, a hydraulic system doesn't or at least isn't supposed to leak.
A high volume pump given say a relief valve setting of 60 psi, will provide a higher hot idle pressure because of the excess volume it moves at any given speed. This is important for a competition or other hard working engine as normal idle oil pressures tend to be low and don't provide enough protection when a high load is suddenly dumped on the engine till enough RPM is built high enough to supply relief valve pressure on the system. This is a case of being able to momentarily overrun the oil supply at the bearings. The down side of a high volume pump is at high speed where there is so much excess flow from the pump the relief valve is always open to vent off the excess volume and pressure. This uses a lot engine power for no useful purpose and heats the oil unnecessarily.
A high pressure pump assumes that the volume it can deliver is far above the engines clearance leakage rate, a stiffer spring is used in the relief valve. This may prove to be an ultimate pressure that can't be achieved till the engine, thus the pump, is spinning quite fast. Again there are several variables occurring at one. Not only is the oil's thickness a concern in the ultimate pump output but so is the pumps capacity which is variable by it's operating speed and its size. Faster delivers more oil than slower. Bigger delivers more oil than smaller.
In the end pressure comes down to how much more oil the pump can deliver into the oil galleys against how fast it leaks past the clearances. Given everything above this paragraph, larger clearances leak more oil than tight clearances. This and pump wear is why a high mileage car will have lower oil pressure than when it was new. This is why or at least one reason why, a competition engine with wide clearances needs a larger volume pump to maintain sufficient pressure against the greater leakage. The other reason for a competition engine is that pressure gap between idle or dropped throttle oil pressure and the sudden need under hard acceleration, this gets into gear selection among other things. Take a road racer that comes of the corner in to high a gear, the engine has too few revs and is suddenly exposed to a fully open throttle. It's very possible that the high lugging load will blow the oil out of the rods and that the pump will not yet be supplying enough volume to make up the loss. Next thing you know it spun a bearing or worse.
For me, I build engines with excess oil pump capacity and my customers live with the slight power loss and an oil cooler. I have found over the years that this results in a lot fewer crankshaft bearing failures. I like to see about 40-45 psi at a hot idle rather than the factory's 15 to 20. For a street engine I usually pop off the relief at 60-70. Beyond that subscription to 10-15 psi per 1000 RPM above 6000 is OK. I run blower and nitrous engines about 10 psi higher in all cases since these devices can really put a lot of load on the rods and mains very quickly.
Old Apr 4, 2009 | 08:17 PM
BALLSS's Avatar
good post Z8's
Old Apr 5, 2009 | 11:06 AM
SoxXpupPeT's Avatar
that was a great article thanks for sharing that. ive been real busy and havent had the chance to go through it yet. so running a high vlm pump would be better if i had a larger oil pan. its a street driven car so me going around a corner in to high of a gear and punching it is going to happen. how much does a new pan run ? i found this one on summit. would it work with a high volume pump ?
http://store.summitracing.com/partde...022+4294924760
Old Apr 5, 2009 | 12:02 PM
7.0 camaro's Avatar
i run hv55's in all my engines. the 383 in the race car see's 7500 on a stock pan. has never went dry. in the lt1 i use 5-30 oil and on start up i have 80 psi of oil pressure. never had a problem either. thats what i do. but thats just me. i build my own engines.
Old Apr 5, 2009 | 12:34 PM
shbox's Avatar
...B] so running a high vlm pump would be better if i had a larger oil pan[/B]. ]
Do run the bigger pan if you are conviced you need an HV pump (not sure why you do). Parasitic drag and excess wear on the drive gear, but do what you want. All opinions have been laid out there for you. I know of a stock, blueprinted pump that supported over 1100 HP.
Old Apr 5, 2009 | 03:21 PM
  #32
BALLSS's Avatar
what ever pan or pump you do go with....do maintain a windage tray.
for some who do auto cross without one....bearing issues.
on 383 motors you can use the stock pan and windage tray just use 1/8" washers between studs and windage tray to clear rods. Miloden makes the longer main studs or you can use your stock ones.
Don't have pics on this computer but the clearance mod with the washers is pretty straight forward.
Old Apr 6, 2009 | 01:06 PM
  #33
SoxXpupPeT's Avatar
ok i sorted it all out with my builder today and he was very cool about it. ill be getting a melling std volume high pressure oil pump. im also going to be boring it out .030 ! i seriously need this week to go by faster
Old Apr 6, 2009 | 02:42 PM
  #34
ls2pontiac's Avatar
Self-Admitted Scammer
I was going to put a high volume M155HV on my brand new stock LT1 shortblock. so i am guessing this is a bad idea then? I have a canton 6.5 quart Road race oil pan tho.
Old Apr 6, 2009 | 03:08 PM
  #35
shbox's Avatar
That pump has the weaker casting. Only the select series of Melling pumps has the the stronger casting.
Old Apr 6, 2009 | 03:22 PM
  #36
ls2pontiac's Avatar
Thanks, do you have a specific part number for the pump, pickup and etc that I need to work with the Canton 242T pan? I can't find it anywhere..
Old Apr 6, 2009 | 03:32 PM
  #37
RamAir95TA's Avatar
Melling 10554 is the standard volume/pressure (comes with hardened driveshaft).
Melling 10552 is the high volume/standard pressure pump (does not come with the hardened driveshaft).
Whichever one you use, go with the 20-023 pick-up (3/4" inlet). When you put the pan on, you'll still want to check for clearance.
I used the 242T, 10552, and 20-023 myself.
Old Apr 6, 2009 | 11:14 PM
  #38
ls2pontiac's Avatar
thanks dude, didn't realize that was you. I will go with the 10554 then. can i still use the 155-S Melling screen that i got? I have the 20-023 pickup too. I would use a high volume if i had a 383, but since i have stock cubes i think it should be fine?
Old Apr 7, 2009 | 06:49 AM
  #39
shbox's Avatar
The engine size has nothing to do with it.
Old Apr 7, 2009 | 04:40 PM
  #40
slingshot928's Avatar
I have that same set up, its good to go....people have told me with poly motor mounts a cheap mellings pump would crack. Anyway, some motors are set up to have crazy loose tolerances so there is less drag...not because they are built like ****....you can gain some free hp during a rebuild by running the looser tolerances....this forum sometimes makes me laugh with the comments on here
