Predictions for new setup?
Old Apr 5, 2009 | 06:52 PM
2XR95Z28's Avatar
Default Predictions for new setup?
Ok so here is the deal, Last year i ran a 13.086 with-
K&N cold air kit
stock manifolds and y-pipe
no cats
Hooker cat-back
3200vig
et streets on salad shooters, stock tire on salad shooters up front
This winter so far i have done-
-226/234 .569/.570 110lsa Advanced inductions cam kit including-
1.6 comp camp rockers (full roller)
obviously all the needed stuff pushrods, guideplates and all that happy crap
Heads have a 5angle valve job, NOT PORTED OR POLISHED
they have been milled slightly and i have .026 head gaskets so it should
be around 11:1-11.5:1 compression
-Pacesetter Long tubes (ceramic Coated) and ORY
-Electric waterpump
-Deleted A/C and pulled all but the box on the firewall
-Tune is from Ion from madtuner, we had it on the dyno and wasnt able to make a full pull but the air/fuel tables and all that was perfect.
Also will have
-Pro-stars all the way around, skinnies up front. Compared to the salad shooters i had all around last year.
-3-way adj Comp Eng drag shocks out back
-WIll have a set of subframe connectors on it before the first track day.
I've done quite a bit this winter and hoping i see a good improvement at the track from all the money i've spent.
What do you guys think for track times? Like i said it ran a 13.086 best ET and had around 101-102mphs preety consistantely. 60's were around 1.70-1.8x's
What are your opinions guys?
Old Apr 5, 2009 | 07:08 PM
Hackscamaro's Avatar
im not sure what you will run but i am about a week away from having my motor with the 226/234 cam as well but i have thier 190cc heads. excited to hear what kind of numbers you put down. do you have a sound clip of the car?
Old Apr 5, 2009 | 07:10 PM
matt94z's Avatar
12.2 @110
Old Apr 5, 2009 | 07:52 PM
2XR95Z28's Avatar
I dont have any good sounds clips yet, and wont have any dyno numbers til maybe may or so or whenever i can get some money to get it back on a dyno.
Old Apr 5, 2009 | 08:52 PM
TABBED 5.3's Avatar
perfect pass = 11.8X good luck.
Old Apr 5, 2009 | 09:00 PM
2XR95Z28's Avatar
i was thinkn high 11's also once i get everything perfect and dialed in.
What do you think i could do with bumping the stall up to 3600 or 3800?
Old Apr 5, 2009 | 09:40 PM
TABBED 5.3's Avatar
I would wait on bumping up the stall until you get things dialed in first. But after that I would imagine that it couldn't hurt
Old Apr 5, 2009 | 09:54 PM
myltwon's Avatar
around a 112mph trap with 11.8-12.2 et
Old Apr 5, 2009 | 10:05 PM
2XR95Z28's Avatar
ya i was hoping for high 11's low 12's
and on the stall it wouldnt be til after i make some runs and see where i'm at. I should still have a free re-flash from buying my vig convertor so we'll see what happens if i go any bigger
