going to the dyno monday
Old Apr 9, 2009 | 08:27 PM
mistamista's Avatar
Default going to the dyno monday
Finally going to the dyno on monday, What numbers do you guy's think it will put down.
Old Apr 9, 2009 | 08:52 PM
TABBED 5.3's Avatar
what "stage 2" heads? Guessing 350-ish. good luck.
Old Apr 9, 2009 | 09:18 PM
myltwon's Avatar
I'd say 360-370 depending on head port quality
Old Apr 9, 2009 | 09:20 PM
TravisMcGill2000's Avatar
342 is my guess
Old Apr 9, 2009 | 09:39 PM
mistamista's Avatar
the heads on the car not sure how they rate them it say's valve seat +.999 2.050 actual depth and then it sayd valve seats +.999 1.620 actual depth and stage II port work done by port pros in austin tx
Old Apr 9, 2009 | 09:47 PM
Puck's Avatar
Port Pros does some impressive work - def worth putting in your sig. Stage II is generic and can be anything from too hogged out local shop ported heads like my last set up to amazing hand porting better then most "Stage III" jobs.
I'd guess ~355 corrected through a manual.
Old Apr 9, 2009 | 09:51 PM
Green3spd's Avatar
6spd car... 359
Old Apr 9, 2009 | 10:22 PM
palt1z28's Avatar
gl 355.
Old Apr 9, 2009 | 11:55 PM
mistamista's Avatar
what are some of you guy's numbers.
