lt1's are so gay
Old 04-15-2009 | 01:33 PM
  #41
Elliott's94Z's Avatar
In the Jeep world I'm all for the Inline 6 engine. Bullet proof! I have seen too many V8's go **** up.
Old 04-15-2009 | 01:36 PM
  #42
93TAJ.C.'s Avatar
Originally Posted by wrd1972
93TAJ.C
You are forgiven.
Your problem is most likely ignition but I would put a fuel pressure gage on the fuel rail so you can totally rule that out.
You can replace the ICM but from my experience those things either work or they dont. I think you have bad connectivity to your plugs. Might want to see if you have any arcing from the wires to ground. You can test this by spraying fine mist of water on the opti and on the wires. If you see sparks or hear the popping then the wires are high resistance and need to be replaced.
Get rid of the NGK's and get some AC Delco plugs and if you need wires, get some MSD super conductors.
I had the same problem a while back and it was bad wires and i diagnosed it the way that I just described.
OH yeah.
And integraxtc can still kiss my ***.
HAHA ok thank you.
I have new msd super conductors, and i drilled all the factory harnesses and ran them perfectly while the engine was out and the headers wer off. i will try the water mist idea. As far as the icm, i know its usually a no start issue, but it just died of of nowhere. The missing is pretty bad at low rpms but seems to go away at wot or above 2000. I just know it wasent plugs or wires that made it die.
Old 04-15-2009 | 01:37 PM
  #43
wrd1972's Avatar
Tis true. My 4.0 sounded like a diesel engine from sticky lifters and had practically no oil pressure. It got water locked a few times too. Could not kill the thing.
Old 04-15-2009 | 01:41 PM
  #44
wrd1972's Avatar
OP,
As stupid as it sounds, make sure the right plug wires are going to the right cylinder. I have crossed 3&5 up several times and ended up chasing my tail for days. Happens to the best of them.
Also you can do a resistance check on the wires with a multimeter and rule them completely out too.
Old 04-15-2009 | 01:59 PM
  #45
93TAJ.C.'s Avatar
This is very true. Heres some more pics
Attached Thumbnails lt1's are so gay-img00364.jpg   lt1's are so gay-img00365.jpg
Old 04-15-2009 | 02:00 PM
  #46
93TAJ.C.'s Avatar
OP,
HAHA yeah i checked that already. The thing that really throws me off is how it intermittent, it just doesent add up. I need to have the time to work on it and really figure it out.
Old 04-15-2009 | 02:01 PM
  #47
Yeah yours would def kick mines *** up in the hills. I've got a baby 4 inch Rubicon lift compared to yours! Sweet Jeep though!
Old 04-15-2009 | 02:08 PM
  #48
93TAJ.C.'s Avatar
Thanks! Its got a d44 with detroit locker and 4.88's out back and the d30 open with 4.88's up front, 6.5" rough country lift with crawler steering, 35" wranglers, yadda yadda yadda
Old 04-15-2009 | 02:09 PM
  #49
phirepower's Avatar
Oh wah wah. It is obviously an ignition issue. Start with the inexpensive checks, remove spark plugs check gap, remove carbon build up or replace. Then check wires for arching, if needed repair or replace. Next Icm. Coil, check for voltage. If all checks out ok. Remove valve covers and check rockers for loose ones, tighten/ loosen if needed. Check optispark, you have an unvented one if you haven't replaced it yet, and seeing how it is a weak link and prone to failure it would be my guess that it may have faulted.
However, it may be even more helpful to have the car F(&*cking scanned, I find it hard to believe that it could be running as shitty as you described it running and hasn't thrown a code.
Tell you what scan it for free at autozone, post the code and I will tell u exactly what the code means. and then direct you on what to replace.
Old 04-15-2009 | 02:12 PM
  #50
Yeah I constantly have to remind myself when I jump in the Camaro that I can no longer drive over curbs anymore
Old 04-15-2009 | 02:13 PM
  #51
RedFire04's Avatar
Ok so on top of having a nasy hesitation and backfireing problem at low rpm's, the car just dies while driving but will start right back up. Is this an icm issue?
This is the exact reason why i've washed my hands with tinkering with this motor. After 10 years and too many problems. Sounds like you need to focus your attention on the ignition side, icm/coil/distributor, opti wire etc.
Old 04-15-2009 | 03:06 PM
  #52
93TAJ.C.'s Avatar
No codes, i would have the frakin code read if there was one. My poti is vented as mentioned about it has msd cap n rotor with converts to vented.
Old 04-15-2009 | 03:12 PM
  #53
djjab57's Avatar
Originally Posted by myltwon
no such thing as a 93 trans am gt
they only made them in 94
I miss my 92 GTA.......
Old 04-15-2009 | 10:29 PM
  #54
integraxtc's Avatar
OH yeah.
:hugs:
Old 04-15-2009 | 11:18 PM
  #55
BLINGOLE's Avatar
LT1 s are gay, huh?
Sorry that your lack of SBC and automotive knowledge is leading to this pithetic conclusion. Your motor probably just hates your frigging guts for being stupid.
Originally Posted by 1badzee
x2 The LT1 isn't gay; You are.
Please sell your LT1 right now and get a V-tec ***-wagon.
Originally Posted by MTBSully
your so gay
+1 dido
Old 04-15-2009 | 11:19 PM
  #56
1badzee's Avatar
HAHA Sorry im not looking for another right now, but thanks....***.
True. Yeah one's enough.
hell yeah dude, jeeping is awsome, im looking for a v8 grand cherokee right now. I it so expensive though!lol
Oh... What happened to you not looking for another one? 0_o
Anyways, sell me your wheels/tires and lift kit. Or I'll just trade you go-fast parts for the bird!! What do ya say!
Old 04-15-2009 | 11:34 PM
  #57
Originally Posted by BLINGOLE
+1 dido
Read the entire thread before posting your pointless reply which contributed ZERO. You may have found that these guys made it good w/ one another and the OP took enough crap already for giving a poor title to his thread.
Old 04-15-2009 | 11:39 PM
  #58
the_merv's Avatar
Damn feel the love in here..lol
Old 04-15-2009 | 11:49 PM
  #59
camar0corey's Avatar
How did the discs look in the Opti when you did the MSD cap and rotor? I put my MSD cap and rotor on like a idiot even though I could see surface rust on the optical discs a few years back. Got back from deployment and the opti **** out a few weeks later.
NAPA should be able to check the ICM. I've had both a bad ICM and a bad Opti over the five years of owning this car, guess what no codes! These cars can run like complete *** and not trip a code, unfortunately. Good luck.
Old 04-16-2009 | 07:44 AM
  #60
wrd1972's Avatar
OBD1 can yes run alike *** and not trip a code. OBD2 is much better at providing codes when things are not right.
Quick Reply: lt1's are so gay
