how do i lift the front wheels
i figure at least:
12bolt or 9"
wide tires
good clutch
interior weight reduction
remove front sway bar
heads and cam
anyone done it on just these simple things? or does it take a lot more...
The question is, why? Its not the fastest way down a track, and the landing is hell on parts. Wheelies can be very expensive.
A small wheelie would actually help, since there would be 0 rolling resistance off the line, but a big wheelie is tme wasted going up rather than forward.
It was a pain in the *** to push it on the Trailer so bring man power of a come-along.
and a tire
get it too hook then spray it and you should have it
a set of adjustables up front
some cheap comp eng drag shocks out back
a decent LCA and relocation barackets
some subframe connectors
and some slicks and skinnies
spray it and hold on
a 4.11 or better gear would help too
it will get it up a little
Here is my car, it is a LSX which helps with weight over the k frame and it makes around 380, but its a heavy car. Take a look.
i figure at least:
12bolt or 9"
wide tires
good clutch
heads and cam
You need to be able to dead hook and have a good sus thats dailed in.
You have to rember you dont want to wheelie more than a couple inchs really or it will start to hurt your times.
