LT1 swap question
Old May 5, 2009 | 11:33 AM
  #41
ss.slp.ls1's Avatar
Originally Posted by RPD_Vette84
throttle body, o2's wiring and plumbing. oh and whatever sensor goes on the front of the waterpump.
oh and pm sent
The sensor is the engine temp sensor. Just make sure that you don't get the wrong sensor (the one that goes in the drivers side cylinder head) by mistake.
Originally Posted by litch2004
all they are is for the heater core. So you can either loop them, put caps on them or find out what size they are and put freeze plugs in there.
+1. I just capped them off.
Old May 5, 2009 | 01:49 PM
  #42
RPD_Vette84's Avatar
do you know a part number or something for that sensor? i tried lookin for it on autozone.com but it only came up with the otherone.
ill probably just loop them then.
Old May 5, 2009 | 04:35 PM
  #43
well i might not need the throttle body anymore cause my exhaust guy who is freakin awesome modded mine for me today.
Old May 5, 2009 | 04:39 PM
  #44
litch2004's Avatar
ok well if in fact that you do need it just let me know it will still be here
Old May 5, 2009 | 04:49 PM
  #45
oh ill still probably get that one from you anyways. itll be a little while cause i jsut check my bank account and i gotta calm down on spending money for a little. sorry man. ill let you knwo though.
Old May 5, 2009 | 05:21 PM
  #46
ss.slp.ls1's Avatar
part#:15326386
http://www.gmpartsdirect.com/results.cfm
Old May 5, 2009 | 05:51 PM
  #47
cool. thanx again sir.
Old May 9, 2009 | 03:42 AM
  #48
hopefully gonna get all the wiring done on it this saturday. hook up the driveshaft. plumbing and that. then pretty much need to delete vats and get o2 sensors and hope its all done by la invasion time.
Old May 9, 2009 | 09:04 PM
  #49
cool got some stuff done today.
soo glad that its at least cranking.
and some new wheels i got that im gonna try to get some nice tires onto.
Old May 11, 2009 | 11:44 AM
  #50
ss.slp.ls1's Avatar
Hopefully once you get VATS tuned out it will start.
Old May 11, 2009 | 01:41 PM
  #51
yeah my buddy that did the wiring for me ended up takin my ecu to his shop to see if he can plug it into this other guys lt1 and delete all that stuff off of it. im hoping he can do it.
so ill hopefully be signing up to la invasion soon.
some more pics
Old May 16, 2009 | 01:31 PM
  #52
Old May 18, 2009 | 11:13 AM
  #53
ss.slp.ls1's Avatar
Nice come up on the n2o kit. I want to add some spray soon.
Old May 18, 2009 | 03:42 PM
  #54
got my new tyres today
Old May 20, 2009 | 02:44 PM
  #55
ok well got a new computer cause mine was fried. found out my motor is really a 94.
went to try to start it but no spark. gettin all the 5v references at places where it should be but nothing. went and got a obd1 daig plug and im goin to hook that up with a check engine light and run the scantools on it and see what it says. i guess if it says low voltage references or whatever then that means OPTI. yay
Old May 22, 2009 | 03:28 PM
  #56
It started!!!!
found that for some reason there was no ignition goin to the opti, so i jumped a wired and tried it out and it started on the first try.
Old May 22, 2009 | 03:40 PM
  #57
ss.slp.ls1's Avatar
It started!!!!
It sounds like it's cammed.
Old May 22, 2009 | 03:55 PM
  #58
maybe cause theres no o2's? its also open header at the moment.
Old May 22, 2009 | 10:13 PM
  #59
so for some reason its not flowing water and the alternator doesnt seem to be charging the battery.
also when i go to kinda rev it up real quick its really hesitant. does that mean the opti isnt workin properly? or could it be cause i dont have any o2's right now?
Old May 26, 2009 | 11:24 AM
  #60
ss.slp.ls1's Avatar
Are you sure you have the coupler installed in between the water pump and the water pump drive shaft inside the timing cover? It's # 39 below:
http://shbox.com/ci/water_pump.jpg
For the charging, you need to check your grounds.
For the hesitation, I would check for vacuum leaks.
