stock windage tray
Old Apr 24, 2009 | 09:03 AM
fergymoto's Avatar
Quit crying about it and do work!
Old Apr 24, 2009 | 09:35 AM
SoxXpupPeT's Avatar
ill cry all i want! i was really looking foward to at least getting her in the engine bay again.. it just depresses me ive been without my baby for over a month! my main concern now is finding my windage tray.....
Old Apr 24, 2009 | 07:21 PM
SoxXpupPeT's Avatar
ok so i talked with my builder today and he said that i had a windage tray but he didnt put it back because it was going to hit the baffles in the oil pan. does that make sense ? and would it be ok if i just cut the baffles out of the pan? or would it cause a problem ?
Old Apr 24, 2009 | 09:39 PM
96capricemgr's Avatar
As has already been well documented by shbox, bone stock they had a tray and baffles they get along just fine.
If I were you I would have a not so great feeling about the build at this point.
Old Apr 24, 2009 | 10:34 PM
BALLSS's Avatar
It is WAY fing better you are dealing with this when motor is out...
Put the motor on the stand and pull the pan. If no windage tray than get one. As mentioned Miloden makes extended studs or you can use GM ones.
"If" you have a stroker motor and use the GM studs put a 1/8" washer between windage tray and mounting points to raise it away from the crank (see pic)
Old Apr 24, 2009 | 10:41 PM
My95Z's Avatar
Lets just hope that b/c LT1's are so very similar to Gen 1's in the rotating assembly area their won't be any problems...hopefully.
Unless the main studs are way different than the stockers were he hasn't even tried fitting it on and is just telling you that b/c he "eyeballed" it. It will fit, did from the factory should now.
Old Apr 25, 2009 | 12:20 AM
SoxXpupPeT's Avatar
im not feeling to well. everything else is fine but this ******* windage tray bs is getting to me. would it be ok to remove the baffle from the oil pan ?
trust me im hoping alot. he told me he had put the tray on but it didnt fit. either which way im pulling the pan before i put it in the car when i have it. and next time ill tear the engine down completely
Old Apr 25, 2009 | 08:17 AM
Thing is the stock windage tray will fit with the stock oil pan baffle, both being stock and all.
Sounds to me like the guy is just trying to get you to go away.
I think it important to differentiate things a little, the stock windage tray "studs" are actually bolts in the way they function twisting the fastener to tighten rather than just a nut. Bolts and studs cause different stresses so it is important to stick to what the block was machined with.
Old Apr 25, 2009 | 10:31 AM
SoxXpupPeT's Avatar
i know it should fit. there both stock and i cant see the studs being THAT off. thing is tho. what kind of issues would i run into if the pan baffles were removed ?
Old Apr 25, 2009 | 11:52 AM
My95Z's Avatar
Well the baffles just try to contol oil and keep it down around the pickup. You might be able to get away with it, but I don't know if I'd chance anything in the oiling system. You could also run into problems with oil control when turning, braking...
Old Apr 25, 2009 | 08:00 PM
SoxXpupPeT's Avatar
yeah i know :\ i really wanna take a look at it myself. i cant believe that something this stupid is stopping me from putting my car back together.. im so pissed still. does anyone else have any thoughts on the removal of the pan baffles ?
Old Apr 25, 2009 | 08:44 PM
  #32
My95Z's Avatar
What stud/bolts are you running again on the mains? (sorry I forget)
Old Apr 26, 2009 | 10:18 AM
  #33
SoxXpupPeT's Avatar
im running ARP's 234-5501
Old Oct 19, 2023 | 02:21 PM
  #34
Gearhedz4life$'s Avatar
Originally Posted by shbox
No, you still need the windage tray. Stock engines have a windage tray AND an oil pan with baffles.
http://shbox.com/1/oil_pan_baffle.jpg
http://shbox.com/1/oil_pump.jpg
So why do some stock lt1 have no windage tray?
Old Oct 19, 2023 | 03:05 PM
  #35
Fast355's Avatar
I have never seen one that did not have a windage tray. By the early 80s most SBCs had a windage tray even. My 85 Z/28 305 TPI had a windage tray. My SBC 305 in my 83 G20 van had a windage tray from GM. My 92 TBI 350 had a windage tray. My Vortecs had a windage tray as well. I would say if the LT1 you saw was without a windage tray, someone had been inside of it and removed it. There are some old school hotrodders out there that think a windage tray leads to cam failure.
Old Oct 20, 2023 | 08:10 AM
  #36
shbox's Avatar
They all have them from the factory.
Old Oct 20, 2023 | 10:45 AM
  #37
BALLSS's Avatar
sometimes the windage tray is not re-installed in 383 builds as the rod bolts can hit it. Windage tray is important. I used washers to space the windage tray away on my 383 build.
