Vacuum pump
My main concern is how it will be mounted. I've seen them mounted on the driver's side head. That's awful close to my turbo. It probably wouldn't hit the pump, but the belt might rub the turbine housing. My turbo is basically where the AIR pump was. Ideally, having it where the A/C compressor was would be perfect. I have lots of room on that side. Share your thoughts!
http://s306.photobucket.com/albums/n...p%204th%20gen/
I have plenty of room on that side for something like that, but I highly doubt I could replicate that.
It seems like the easiest way to create vacuum all the time is a vacuum pump (except they are expensive and require a lot of work). But again, the stock systems, from my understanding do not pull vacuum at WOT which i would think being the most important time to pull vacuum for blow by. Anyways, im glad someone is asking about this because i was hoping some sort of system would be great other then the vacuum pump, I'm still tempted to try and make the exhaust system work but we'll see. Any insight would be great on this subject.
A vacum pump would be the best of both worlds, and it would need to be plumbed to a vented catchcan that will need to be emptied on a regular basis as you will pull plenty of moisture & it will fill the can pretty quickly. A belt driven one being the most reliable, and you will need to install a vac relief valve in the opposite valve cover you pull from to prevent to much vac. Any more than 12-14 inches will pull in seals & pull oil off the main journals & wrist pins causing failure. You will also need to attach a filter/breather to the vac relief valve to prevent dirt/dust/debris from being pulled into the motor.
The problem with a belt driven vac pump on the street is durability. On our dragsters we would rebuild them every season....and that was just from running down the track a 1/4 mile at a time....not daily street driving. The Moroso & Aerospace components units use carbon vanes that float in a rotor assy to generate vac and thease will wear as well as the bearings & seals. I have used elec ones on street cars also but have had them fail (the OEM air pump works well) when run continuesly.
The most proven system that properly flushes the harmful crap from your crankcase continues to be a proerly set-up PCV system with one way check valves and a good baffeled 1 qt plus capacity oil seperating can.
My catchcan setup is excellent for venting off a lot of pressure. But it will not create a vacuum to help out blow-by and ring seal. That's why I'm seriously considering a vacuum pump. I might be able to mount it on the driver's side head but I would have to get some measurements to see if it will hit the turbo.
I still would like to see some pictures from the people posted.
i had a bracket cnc-ed to fit down low on the block , i didn't like it way up top on the drivers head. I took the head bracket to a local cnc shop and told them to keep the pump bolts in the same location, but move the other two hole to a specific measurement. only cost me 60.00.
I had to mount the catch can lower than most because the pump is lower, i didn't figure it would drain running up hill.
I asked GZ about them developing one for the LTX crowd but go no response. There is a thread in the FI section discussing a new setup so maybe if enough of us chime in we'll get some positive feedback.
https://ls1tech.com/forums/forced-in...mp-system.html
But those don't incorporate our accessory bracket which would be the main difference between a sbc kit and lt1 kit.
