Speed Inc cadillac cam vs. lloyd elliot sleeper cam
Old 04-27-2009, 01:07 PM
94Aquaformula's Avatar
Default Speed Inc cadillac cam vs. lloyd elliot sleeper cam
Hello guys,
Does anybody know the difference between both these companies’ cams that are "sleeper cams?" I have heard both great feedback on each others cam. Wanted to know from people who have them in there car, and how much power it gave you. These are very good companies so I'am not starting a fight. Just want to hear some good info. Try to make my decision on which one to go with. Thanks Calvin
P.S. anybody have any video clips with these cams and dyno sheets?
Old 04-27-2009, 01:20 PM
ss.slp.ls1's Avatar
Originally Posted by 94Aquaformula
Hello guys,
You already have headers, exhaust, and ram air...why do you want a sleeper cam I'd think bigger.
Old 04-27-2009, 01:27 PM
i just dont want to change the stall,gears and heads. just want to throw it in. stall is 2000 gears are 3.23 and heads are stock.
Old 04-27-2009, 01:36 PM
ss.slp.ls1's Avatar
There are many cams you can run effectively on stock heads, I am running the CC503 w/ stock heads for example. You will want to change your stall though, 2000 is very small, even for a bolt-on car. Get a 3200+ stall and get a decent sized cam. Then save up for gears.
Old 04-27-2009, 01:41 PM
i almost bought that cam but its way out of my budget for doing it right. such as stall, tranny cooler, gears,shift kit, valve train parts and so on.
Old 04-27-2009, 01:43 PM
ss.slp.ls1's Avatar
What's your budget?
You'd have to upgrade your valve train with any cam you choose...
A larger stall and 3.73 gears alone will make your car a different car, without going into the internals.
Old 04-27-2009, 01:45 PM
I just spent alittle over 4000 to have the motor rebuilt and tranny and pay to have it installed.
Old 04-27-2009, 01:46 PM
i have lt4 springs and cc 1.6rr brand new with cm pushrods.
ss.slp.ls1's Avatar
So what's your budget now? You should install yourself, saves a bunch.
Old 04-27-2009, 01:47 PM
ss.slp.ls1's Avatar
Well LT4 springs are only good enough for 1.6 rr's and the stock cam. Anything larger and you need better springs.
Old 04-27-2009, 01:53 PM
yeah i know. i have taken out a couple lt1s and put them back in my friends car. It gets old and dont have the space anymore. i have seen people using stock springs and such with the sleeper cams.
Old 04-27-2009, 02:05 PM
StealthFormula's Avatar
Stock springs cannot be used with anything other than the stock cam. They are not strong enough and will go into coil bind. You could have serious issues result from that. The LT4 springs you have will more than likely have to be replaced to run either of those camshafts but your best bet would be to talk to Lloyd or Larry because they would be able to tell you for sure since I am unaware of there lobe designs etc. Keep in mind the LT4's probaly can't even handle the lift of either with 1.6RR's so you would have to downsize to 1.5's which would kind of contradict everything.
My vote is to up the stall and gears in time because you will see more noticible gains by doing that than putting in a small cam with the setup you currently have.
Old 04-27-2009, 02:11 PM
kinglt-1's Avatar
+1 well put.
Old 04-27-2009, 02:12 PM
Don't know if you guys have seen this thread very very old. Check it out and tell me what you think. Look at his mods. https://ls1tech.com/forums/lt1-lt4-m...o-results.html
Old 04-27-2009, 02:17 PM
As far as I can see stock valve train is used. I called Larry just waiting on him to return my message.
Old 04-27-2009, 02:20 PM
kinglt-1's Avatar
notice that was installed with comp springs NOT stock or lt4! Which is what everyones point is here. Thats why guys are saying to go with a bigger cam. you are going to have to upgrade the SPRINGS anyways lol.
Old 04-27-2009, 02:23 PM
ss.slp.ls1's Avatar
From thread you linked...
"...I also installed Comp 1.6 rockers and comp springs/retainers."
Trust me, you can't run stock valve train...
Old 04-27-2009, 02:25 PM
kinglt-1 I didn't see that they used cc springs. Thanks for pointing that out. I can buy better ones to put on the sleeper cam if needed, just waiting for larry.
Old 04-27-2009, 02:30 PM
The springs i bought are from bullet racing cams. The sticker on the side of the box says this.......
Bullet Racing cams
vs 958
1.250 O.D. w dampner
115# @ 1.700
305 @ 1.200 bind 1.125
mean anything to you guys, I got them from a great performance shop here in town and are known around. Patterson Racing Inc. The have a bad *** lt1
Old 04-27-2009, 02:35 PM
There is another coil, "I guess you could call it" inside of the spring.
Quick Reply: Speed Inc cadillac cam vs. lloyd elliot sleeper cam
