58mm Throttle Body
Old Apr 30, 2009 | 03:40 PM
BOLO's Avatar
Default 58mm Throttle Body
Is there a significant increase in performance upgrading from a 52mm throttle body to a 58mm? BTW, the car is running a heads and cam combo with all the bolt ons and 150 shot. Just wondering if its worth to swap. Thanks
Old Apr 30, 2009 | 04:16 PM
za355tx's Avatar
It will make a difference but nothing you probably would be able to feel. At the track probably a tenth or so. My old man sold a 58mm tb to Javier97Z28 in his LE 355 car and he runs low 11's. He picked up about a tenth from going to stock tb size to a 58mm. So assuming you're putting down more HP since you're hitting a 150 shot along with heads and a cam I would feel comfortable telling you it could gain you at least a tenth but maybe more assuming you hook up.
ss.slp.ls1's Avatar
Only if you sold your 52mm TB to recoup some of the cost of the 58mm TB. Even then I wouldn't hope for much.
Old Apr 30, 2009 | 05:07 PM
BOLO's Avatar
Thanks guys, I think I'll spend the money elsewhere.
Elliott's94Z's Avatar
It would be very minimal. If you did the 58mm I would have your intake ported by AI or LE at the same time to really get the full benefits.
Old Apr 30, 2009 | 05:18 PM
BOLO's Avatar
Intake was already ported by Speed inc.
Old Apr 30, 2009 | 05:26 PM
With that said, if you can sell yours and put the $$ towards a 58 then do so. Gains will be very minimal. Kind of a peace of mind thing knowing you have it
Old Apr 30, 2009 | 06:01 PM
AChotrod's Avatar
Id sell the 52 and pick up the 58 in the end it will help.
Old May 1, 2009 | 04:54 PM
Bowtie Boy's Avatar
Stock...most likely not at all.
H/C/I (intake being ported to 58mm, stock openings are 54) then yes.
