whats required with lt4 hot cam kit
Sounds nice huh! Pulls hard too from the dig. You would have to get True Duels in order for it to sound like that though. Another thing you can do is install an electric cut out for some extra HP and great sound. I put a DMH on mine and it sounds awesome. http://www.fquick.com/videos/LE2_Z28...c_Cut_out/8212
On a side note, the 12551483 springs that come in the hotcam kit will work just fine for that cam, no need to upgrade until you go larger. Also if you have to pass a visual inspection in your state Long-tubes will not get the job done. You'll need to go with mid-lengths.
He doesn't need to go with mids if he gets the LT's with the emission hook ups. Plenty of guys here with the LT Pacesetter Emission headers that pass just fine with the visual.. Oregon has one of the most strict emission/smog laws as well. Yes, the Hot Cam is a good kit but for the money he will get a much stronger/reliable set up piecing one together w/ a custom grind and going with better components for pretty much the same price.
+4 on going with a custom grind.
Arctic your about the only one on here that's for the LT4 so I would say you are a little out numbered. If it was 1984 it would be a no brainer but we are well into the 2000's and better stuff has come along. The emission Pacesetter with the hook ups with pass just fine. Been there gone that route before and never a issue. That's why they make them afterall right?
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
Of course the emissions hook-ups are intended for emissions equipment, BUT that doesn't mean you will pass smog just because you have EGR and A.I.R provisions. Remember your in Arkansas. I imagine laws are a bit looser down there. Try to pull into your typical smog shop down here with "Emissions Compliant" Long-tubes and they will quickly issue a fail slip and send you on your way. Once again IDK how other states do it but I would hate for the O.P. to go through all the trouble of installing LT's and then have smog issues.
On a side note, beautiful Camaro in your sig pic!! Is it an original SS? I noticed your screen name is "Elliott's94Z" so I was thinking maybe clone??
I wouldn't call passing the last 5 years lucky. They have seen my long tubes each time and never second guessed them. Have a buddy with a 96 LT as well that has passed with his to.
#32
#34
yea its pretty fun when ricers pull up and its closed and then open it, i always close it whenever i see cops too, but its not even that loud i cant wait till i get headers, which i think im gonna go with pacesetter lt's then ill just do the cutout after the y and then the cat
