O2 question
Old May 6, 2009 | 09:11 PM
jrock692's Avatar
Default O2 question
I just put long tubes on my car and I extended the o2 wiring by cutting and soldering. On the passenger side I forgot to mark the two brown wires so I would know which one was which when I soldered them back together. Would it make a differance if they got swapped?
Old May 7, 2009 | 06:59 AM
jrock692's Avatar
ttt....
Old May 7, 2009 | 12:27 PM
ss.slp.ls1's Avatar
According to this diagram:
http://shbox.com/1/HO2S_connector.jpg
I don't think it matter if you mix up the two brown wires. They are for the heater circuit.
Old May 7, 2009 | 12:43 PM
JAKEJR's Avatar
On the 3 wire heated 02s I've installed on L98s those two can go either way; ground or switched 12V.
Jake
West Point ROCKS!
Last edited by JAKEJR; May 7, 2009 at 12:45 PM. Reason: Specified 3 wire heated 02s
