cc503 cam setup help.
Old May 7, 2009 | 02:42 PM
ALEXZ28's Avatar
Default cc503 cam setup help.
i bought a cc503 cam, i wanna make sure b4 i order if i can run this set up. for the springs i got Edelbrock 5792 Valve Springs, Single, 1.550 in. Outside Diameter, 1.070 in. Coil Bind Height, Set of 16. and for the rr,COMP Cams RP1417-16, which is Rocker Arms, Stud Mount, Roller Tip, Steel, 1.52 Ratio, Fits 3/8 in. Stud, Chevy, Small Block, Kit. what do u guys think about it? thanks
Old May 7, 2009 | 08:55 PM
stevema10631's Avatar
i have the cc503 its a good cam, what is max lift on those springs? that is one of the first thing i would look into also is there a reason your going with 1.52's and not 1.6's?
Old May 8, 2009 | 09:01 AM
JAKEJR's Avatar
I'm also wondering if your heads can accept a 1.550" diameter valve spring. You didn't mention which heads you're running.
Jake
Old May 8, 2009 | 10:34 AM
sepno77's Avatar
i believe he is runing stock heads and is on a real low budget so needs to keep his cam only lt1 build simple as possible and is looking for sugestion on this kit...
Old May 8, 2009 | 11:07 AM
1eyedmaro's Avatar
i would go with 26918's personally
Old May 8, 2009 | 11:20 AM
ss.slp.ls1's Avatar
I have a CC503 cam-only LT1. I did a lot of research and I found that the best spring for the money for my build was the Crane 10308 dual spring kit. Drop in replacement and it should handle ~.600" lift. Works great in my car so far.
+1 on going with 1.6 ratio rockers over 1.52.
Old May 11, 2009 | 05:56 PM
sepno77's Avatar
ok my brother wanted me to post this so here gose....
(whats the cheapest springs he can use for the 503 cam?) part # plz
Old May 11, 2009 | 05:57 PM
ss.slp.ls1's Avatar
Old May 11, 2009 | 06:52 PM
sepno77's Avatar
Are there any other cheaper ones I don't think he wants those.
Old May 11, 2009 | 06:59 PM
Puck's Avatar
Springa are not where you want to go cheap at.
I ran the 10308 kit for about two years daily driving a custom 22x/23x cam with .570 lift on both sides. For a mild cam it is hard to beat. Peaked at around 6k just like they said it would with no sign of valvefloat.
Old May 11, 2009 | 07:24 PM
ALEXZ28's Avatar
its the money im worried about, the springs 10308 dual spring kit is`out of stock for 2 -3 weeks thru the company who im getting all my parts. im just going to go thru summit. so far i got the 1.6 rr and the camp cam 503 and ill order these springs thanks guys
Old May 11, 2009 | 07:26 PM
ss.slp.ls1's Avatar
Why doesn't he want these exactly
Old May 11, 2009 | 07:27 PM
ss.slp.ls1's Avatar
Let us know how it goes.
Old May 11, 2009 | 08:26 PM
gregrob's Avatar
The Patriot Gold dual springs are a great bang for the buck...
That's what Lloyd recommended I run, although the cam will be a tad more aggressive than a cc503... lol
Old May 12, 2009 | 03:00 AM
gregrob's Avatar
Oh and I hope you have budgeted for pushrods and guideplates if your rockers are nsa. That as well as gaskets and incidentals can add up to more than u think, quickly.
Old May 12, 2009 | 03:02 AM
ehnihl's Avatar
That's a nice cam dude...
Old May 12, 2009 | 05:59 AM
duckvader's Avatar
go to competition products . they have a drop in spring where you could use your stock retainers etc. and i think there only 80.00 part no 98213.
Old May 12, 2009 | 06:13 AM
duckvader's Avatar
call competition products. talk to tech to find out for sure about drop in springs. nice folks. i have ordered from them.free shipping, only 10.00 handling like summitt.
Old May 12, 2009 | 07:35 AM
ALEXZ28's Avatar
ok so i got the Crane 10308 dual be here fri, now i was told that i should change the timing chain what do yall think???? and push rods, i was told i can use the stock rods.
Old May 12, 2009 | 11:22 AM
pillarpod's Avatar
How many miles you got on the motor? if its over 30,000 miles i would totally replace it.
