cc503 cam setup help.
Old May 12, 2009 | 11:30 AM
ss.slp.ls1's Avatar
Originally Posted by ALEXZ28
ok so i got the Crane 10308 dual be here fri, now i was told that i should change the timing chain what do yall think???? and push rods, i was told i can use the stock rods.
Timing chain is not absolutely necessary, but it is good insurance to replace it.
You need hardened pushrods. Summit has Trickflow chromemoly pushrods for ~$87.
Did you get NSA or SA 1.6 rr's?
Old May 12, 2009 | 05:51 PM
sepno77's Avatar
he got NSA
Old May 12, 2009 | 06:11 PM
ss.slp.ls1's Avatar
Originally Posted by sepno77
he got NSA
So do I.
Old May 13, 2009 | 09:01 AM
ALEXZ28's Avatar
do u know what size rods ill need so i can go ahead and order them?
Old May 13, 2009 | 09:41 AM
ALEXZ28's Avatar
Originally Posted by duckvader
call competition products. talk to tech to find out for sure about drop in springs. nice folks. i have ordered from them.free shipping, only 10.00 handling like summitt.
http://www.competitionproducts.com/p...p?number=98213
are these the ones that ur talking about? ill call and see if these will work?
Old May 13, 2009 | 11:19 AM
ss.slp.ls1's Avatar
If all you are doing is swapping cams, you should be fine with 7.2" pushrods. But measuring to be sure is always preferable.
Old May 13, 2009 | 06:51 PM
8595transam's Avatar
I sent them an e-mail and he said they would work fine as long as you install them at 1.750. That gives a 145lb. seat pressure at that installed height.
Old May 14, 2009 | 07:15 AM
ALEXZ28's Avatar
so i can use everything that came off my stock springs and add to these springs?
Old May 14, 2009 | 06:39 PM
I believe so.
Old May 23, 2009 | 06:21 PM
ALEXZ28's Avatar
I don't understand what it means set it at a 1.75,
Old May 23, 2009 | 08:15 PM
smb72's Avatar
I went with CC503 cam and 1.52 roller tip rockers but had to get the Crane springs due to CC beehive springs being out of stock for a month. Everything else is stock. Runs great untill my opti went south
Old May 23, 2009 | 08:20 PM
  #32
gregrob's Avatar
That refers to the installed height of the springs, which affects the opening and seat pressure as well as the point where coil bind could occur.
You install the springs then measure how tall they are, if they are less than the reccomended height you add shims to bring them up to that level. If they are taller you live with it unless you have the springs pockets machined deeper.
Old May 25, 2009 | 10:18 AM
  #33
ALEXZ28's Avatar
Ok I got the springs on, now how do I set the rr, I kinda have an idea but I wanna make sure its done right.
Old May 26, 2009 | 11:43 AM
  #34
ss.slp.ls1's Avatar
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
For best results, do BOTH the engine off and engine running method. Use the engine off method to get the valve lash in the correct ball park. Then start the car and reset the lash with the engine running. That's what I always do.
