How do you delete the oil cooler?
Old May 8, 2009 | 05:16 PM
1badzee's Avatar
Default How do you delete the oil cooler?
I am doing my TH350 swap so I decided to replace all the seals on my motor since most of them leak anyways
I sat and looked at the oil filter housing/oil cooler and I cannot figure out how to remove it and what to replace it with. I haven't tried doing it so maybe it's self explanitory when I do. Anyways, any tips would be great.
Old May 8, 2009 | 05:27 PM
ss.slp.ls1's Avatar
Once you remove the oil filter, you should see two bolts that hold the oil filter adaptor to either the oil cooler or the block. Remove it and then remove/unbolt the oil cooler form the block, then bolt the oil filter adapter right to the block. Should be very simple.
Old May 8, 2009 | 05:29 PM
1badzee's Avatar
Unfortunately I see neither lol. Just one retaining nut over that long stud/pickup tube that the filter screws on. Can you show me a pic of these bolts? I see none 0_o
Old May 8, 2009 | 05:40 PM
ss.slp.ls1's Avatar
Don't know if this helps...
http://www.lt1info.com/TECH/Cooling%...ler_lines1.gif
Old May 8, 2009 | 05:41 PM
ss.slp.ls1's Avatar
I see a bolt in this picture:
Old May 8, 2009 | 05:43 PM
ss.slp.ls1's Avatar
Default Delete Thread
This thread has everything you need with pics:
http://www.impalassforum.com/vBullet...cooler+adapter
I take it back about the oil filter adaptor. It looks like you need to get one. You can get one from a junkyard or new from Summit.
Old May 8, 2009 | 05:46 PM
1badzee's Avatar
Oh, the bolt for the actual lines? Yeah I removed the bolt and lines.. but what, do I leave the cooler just open like that?
edit: okay I see now..
Old May 8, 2009 | 05:47 PM
ss.slp.ls1's Avatar
Did you read the thread above?
Old May 8, 2009 | 05:48 PM
1badzee's Avatar
Thanks
Old May 8, 2009 | 05:59 PM
SoxXpupPeT's Avatar
it might be a different set up like the one i had on my 94. unscrew the filter and the threads should have a 1 1/16" bolt head that you unscrew to remove the sandwich adapter
Old May 8, 2009 | 06:54 PM
Puck's Avatar
I did not need an oil filter adapter. Just remove the oil cooler then cut the studs off the bolt heads and you can reuse them, then screw the filter right onto the block. Get a tall filter to make it easier to put on.
It didn't cost me a cent
Old May 8, 2009 | 07:45 PM
litch2004's Avatar
i remember unbolting those lines off of my oil filter adapter with that bolt in the center between the lines but mine didn't go up to an oil cooler. Mine actually attached to the water pump and the radiator
Old May 8, 2009 | 07:57 PM
1badzee's Avatar
That bolt is what holds them to the cooler..
Old May 8, 2009 | 08:16 PM
ss.slp.ls1's Avatar
Yeah, because instead of piping the oil to a cooler, our cars piped coolant through the special oil cooler adaptor which cools the oil as it passed through it.
Old May 8, 2009 | 08:21 PM
litch2004's Avatar
so is there a benefit to the way my year was done? Or is there a benefit to removing it like what other people are doing?
Old May 8, 2009 | 08:41 PM
93cz28's Avatar
press the "Backspace" button and it should get deleted.
Old May 9, 2009 | 12:31 AM
1badzee's Avatar
I did "select all" and "DEL"
Old May 9, 2009 | 01:06 AM
NorthernZ's Avatar
sooo, other than woring about the posiblity of a leak is there a benifit to taking the cooler off?
Old May 9, 2009 | 01:05 PM
93cz28's Avatar
think u get better oil pressure and get longtubes to fit.
Old May 9, 2009 | 03:20 PM
JAKEJR's Avatar
Years ago, I did back to back tests with the oil cooler installed and then removed on my 86 Vette. I drove on the street and the interstate at the same speeds (rpms) for the same distances on the same day. I did everything I could to do an apples to apples test.
What I found was my oil temperature ran 20-25 degrees higher with the cooler removed.
Jake
West Point ROCKS!
