sputtering bad only in heavy rain?????
whenever it rains heavy the car starts sputtering, skipping, and backfiring until i shut it off and restart it....then it runs fine. and when i have to go through a puddle that i cant avoid it starts running like crap again until i shut it off and restart. so what gives???? two of my friends with lt1's do not have this problem. Trending Topics
It does sound like an ignition thing though, maybe a wire is damaged, maybe the cap and rotor old or not well sealed, maybe the vent harness is in bad shape.
The fact that the car works just fine when you restart it is because when the car first starts up it uses a default program where it ignores the 02 sensors. After it recieves a signal from the temps sensor saying that it is warmed up, It goes into Closed Loop and actually starts taking the 02 sensor readings into consideration.
yes mine are spliced! man i'm glad you posted this!!!! that has to be the problem. did you end up getting "real" o2 extensions?
