I did it!! LS1 Lid and Base on LT1 Camaro!
Old May 18, 2009 | 06:59 PM
redt/a2000's Avatar
Has anyone yet to find the actual dyno results for this conversion. I just have trouble actual thinking this actually makes any hp differrence.
Old May 18, 2009 | 07:03 PM
the_merv's Avatar
Veteran: Air Force
I gained about .25 sec.
Old May 18, 2009 | 07:10 PM
Chris Gage's Avatar
That is a pretty big gain. How much MPH did you gain by doing the conversion and was it on a LTx motor?
Old May 18, 2009 | 07:45 PM
redt/a2000's Avatar
But no one has dyno numbers,or mph gains?
Old May 18, 2009 | 07:55 PM
Chris Gage's Avatar
For what it is worth, I dont think dyno numbers are that big of a deal withthis type of mod since the dyno doesn't relicate the amount of air to the lid/cai, this is why I ask about mph.... a .25 gain could be seen by alot of different varibles. Well that is what I would think anyways. I havent done much research on this but I would be interested in seeing the mph gains to judge how much somethign like this is worth on a LTx car.
Old May 18, 2009 | 10:57 PM
Black94Z28's Avatar
Originally Posted by multmigs
so my ??? still remains did you chop a section of the metal out inside for the air??
Nope, just bolted your base on, put the lid on, hooked everything up and good to go. Only thing I trimmed was underneath the hood. Once I opened up the cowl more, it gave me room for the lid.
Old May 18, 2009 | 11:56 PM
96lt1m6's Avatar
dyno numbers will not tell you jack crap with a ram air set up for the simple fact that NO AIR is being rammed in at speed!
i gained 2tenths and 1.8mph same day,track within 15 minutes the facts are there if you base every mod from their claim of dyno hp you will have a 500hp 12 second car.....
the merv had it on his Lt1 then he built that Ls hotrod and its workin hard on that motor too
Old May 19, 2009 | 11:35 AM
Vicious95Z28's Avatar
Originally Posted by Black94Z28
Multmigs-i just slapped on the base you sent me. No trimming done on it.
All I had to do for trimming was just the underside of the hood. And basically is was just some fiberglass that was under the cowl scoop. I will snap some pics tonight or tomorrow of the hood, but I haven't smoothed the edges out yet, so it looks a little rough. Shouldn't be noticable after I'm hoping.
Dude, I'm not concerned with how rough it looks, I just wanna see where the cut was made.
Old May 19, 2009 | 12:37 PM
the_merv's Avatar
Veteran: Air Force
About 2mph on the auto setup.
Yea, it works really well on it too. I took the Fog Lights out and cut all that steel out, also took the Washer Fluid Resivoir out so basically it's ram-air.
Old May 19, 2009 | 06:59 PM
Black94Z28's Avatar
I promised pics of the underside of the hood where I cut for the LS1 lid. Granted this is a rough cut and will clean it up with a dremel soon, but here is what was taken out
The LS1 lid and base setup...
Old May 19, 2009 | 07:06 PM
the_merv's Avatar
Veteran: Air Force
Nice.. that's one way to do it.
Old May 19, 2009 | 07:10 PM
  #32
Black94Z28's Avatar
Now when I detail the engine bay out (which needs it BAD!!) ill cut and trim so the cuts look like they were made from the manufacturer like that. Then spray some black paint over it and call it a day
Granted I did some other work to the car since I last drove it (weight reduction, LT headers, and deleted power steering) It does pick up ALOT faster.
Old May 20, 2009 | 11:56 AM
  #33
Thanks bro. how much raise do you think the cowl has in that particular spot? I just wanna compare to my VFN.
Old May 20, 2009 | 12:10 PM
  #34
the_merv's Avatar
Veteran: Air Force
It's going to add a pretty good amount of power cause the travel distance for the air is considerably shorter.
Here's how I did mine.. I kept the stock Hood so I have to recess the Lid ontop of the Radiator..
Old May 20, 2009 | 04:17 PM
  #35
Mighty Whitey's Avatar
back to back dyno results from a moroso CAI to an LS1 lid swap, on a '95 t/a (the same guy that posted pics of his car with the eficonnections LS1 pcm/coil per cylinder swap in another thread) netted 10rwhp over the CAI. and the same car with a stock intake gained another 10rwhp with a cai over a stocker.
so, 20rwhp from a stock intake, to an LS1 lid.
Old May 20, 2009 | 04:27 PM
  #36
Z28_LT1's Avatar
but did that car have any other bolt ons like LTs or mids or was it absolutly stock?
Old May 20, 2009 | 04:29 PM
  #37
Z28_LT1's Avatar
Hey OP, what did you use between the MAF and the TB?
Old May 20, 2009 | 04:39 PM
  #38
rufrntn's Avatar
LS1 Bellow (probably replace with smooth one down the road)
Old May 21, 2009 | 11:35 AM
  #39
I looked @ my hood this morning and it looks like I'd have to do a lot of hacking on the hood without any guarantee that it would even fit afterwards. Oh well, I guess I'm stuck with what I got.
Old May 22, 2009 | 07:56 AM
  #40
Black94Z28's Avatar
I would say the 4 inch is perfect, it looks like when its closed (me looking through the cowl opening lol) the lid follows the incline of the hood and probably has 1/4 of an inch gap, so i dont know if a smaller hood would work.
