ABS inop??
Old May 21, 2009 | 12:59 AM
Bad_tx_Z28's Avatar
Default ABS inop??
well i hoped into my car today to go run some errands. I got about a block away from the house and noticed that my abs inop light was on. When i got to where i was going i shut the car off and let it sit for a few mins. I re-fired it and the light was gone. On my way home the light came on again and hasnt been off since. I tried disconecting the battery and it didnt help. What do i need to do or check?
Old May 21, 2009 | 01:23 AM
tspence45's Avatar
I believe it may come on if the bulb is bad on your third brake light. It's somehow wired into it. I used to have it come on whenever it rained for some reason, then it'd turn back off a couple days after. Then, after we had some big rain last year, and I let my car sit for a few days while on was on vacation in Arizona, it never came back on after. So, I don't really know what the deal was with it.
Old May 21, 2009 | 09:41 AM
Bad_tx_Z28's Avatar
My did the same not too long ago when it rained, but then it went back off. Now its on all the time. I might take it to my buddies shop today and let him check it out.
Old May 21, 2009 | 09:54 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
bad wheel speed sensor, different size tires front to back, third brake light out, etc
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 21, 2009 | 10:25 AM
kinglt-1's Avatar
Not to hijack thread, but my abs inop light has been on for years. I had it looked at by a shop and they said the code was a rear ground fault. They recommended changing the rear abs electrical harness, so I did and still same deal. I was wondering If I should change the rear abs sensor, thanks! Oh btw I did blow up my diff from launching about the time this started, so that makes me wonder if the rear sensor got damaged.
Old May 21, 2009 | 10:29 AM
96blackta's Avatar
Mine came on once or twice after I bought the car. I've replaced the rotors all around and not had a problem since.
Old May 21, 2009 | 10:41 AM
Bad_tx_Z28's Avatar
i have the same size tires all around. I will have to check the third brake light later.
Old May 21, 2009 | 01:04 PM
creepingdeath94's Avatar
I have a similar issue here except if I don't take out the little 5 amp fuses under the hood for the ABS, it will occasionally flicker the "brake" and "low trac" lights as well and the ABS will come in and out a bit as I stop once in a rare while. My bet is on a wheel speed sensor as it is obviously getting signal to react/operate from something and the solenoids are working enough to pump the ABS sometimes when stopping. I will get a scan tool on it one of these days and see if i can diagnose a wheel speed sensor or at the very least check/test them.
Old May 21, 2009 | 01:08 PM
Flamingchicken94's Avatar
Mine came on after I put lowering springs on my car..
not sure if it was related to it, or just a coincidence? I figured it was a wheel speed sensor so I havent messed with it.
Old May 21, 2009 | 05:57 PM
litch2004's Avatar
Mine did this forever, every time i had it checked i changed what it was. so i finally did a ABS delete. Replacing the ABS system was way too expensive, plus weight reduction
Old May 21, 2009 | 06:19 PM
nik1703's Avatar
mine has been on for a year, i dont really care. I think its brake light related, my spoiler light hasn't worked since i swapped the hatch
