Canton 242-t windage issues?
My fix was removing the stock pan and windage tray and installing the milodon 7 qt pan and moroso rear pan baffle. The most important part was this baffle that went inbetween the oil pump and rear cap. After that I run 5.5qts in the 7qt system three years now no more pressure drops AND HAPPY BEARINGS. Do not drive the car with the pressure dropping until your sure the guage is faulty. Everyone said my guage was bad but it wasnt, the air was compressing in the oil pump.
I have the same pan and a Melling select pump. I run a K&N long filter and 5 quarts in the pan. Barely touches the stick. On long cruises I put in an extra quart.
WHat I have noticed is mine only does it when the oil is hot, when the oil is cold it will almost peg the gauge on startup. I have never run the car hard when its cold though. I have never had the ***** to WATCH the gauge, just glance at it.
WHat oil is in the car?
First thing I would do is put a good gauge in the car.
It could be a faulty pump as fastfatboy said, bad guage or your getting oil in the rotating assembly. Gauge first if that doesnt fix it pull the pan an put the baffle in it.
I tried everything first because I had to pull my pan without a lift, it stinks.
10w30 penzoil synthetic, I always wait for the oil to warm up before I get on it too. Oil pressure is 60-70 cold, ~30 hot idle with 50-60 cruising.
Skimming over the thread, I don't believe this was mentioned, but you might check your dummy distributor shaft at the rear of the lifter valley. It has a plastic retainer holding it to the block. The gear on the end of the shaft is turned by a gear on the rear of the camshaft, and this in turn drives your oil pump. If that dummy shaft is lifting off of the camshaft at high RPM, that will *definitely* cause a loss of oil pressure until the dummy shaft comes back down into contact with the camshaft gear.
For this reason, I welded up a metal retainer for the dummy distributor shaft. A company used to make something like this years ago, but they've since gone out of business.
I don't have pictures, but mine wasn't anything fancy -- it was just a brace, using what I had laying around. Think I used 1/8" or 3/16" flat metal stock (cut into the shape of the top of the shaft), and then welded on a round bushing that fit the I.D. of the dummy distributor shaft -- as well as using a longer stainless bolt w/ lock-washer and red threadlock. Probably cost me all of $3.00.
