388 finally runs, startup vid inside!
400 rwhp haha i dunno man, anything over 450 rwhp will be cool, my car doesn't have a cage so i won't be able to dial it in on motor, much less on nitrous. Anything it doesn't make on motor will be sprayed. i've got a cola crank, manley rods, and custom JE nitrous pistons, studded 4 bolt block, head studs (they don't leak!), etc. so there's room to grow to a SR setup, maybe even a carb'd setup. I'll post numbers later this week though.
Did you say that is a HR cam. You are one of the only other guys on here runnin as big of a HR as me. Please post numbers after single plain.
Dont go carbed keep it LT1 style mane
decided to keep the lt4 manifold, i'm getting a new cam (bigger n better) from bret bauer probably in about 2 weeks, doing an e85 conversion, then i'll post some new numbers. it made 480/459 with the cam that's in it right now. Yes is a HR with solid lobes.
