need help pullin motor
Old May 27, 2009 | 06:36 AM
z28rob18's Avatar
Default need help pullin motor
hey guys i need some help. we got the motor completly unbolted and the trans and all. hav the front lifted some but i ran into a small problem. were usin a engine hoist to lift the front of the car. so the front is lifted some with the motor still on the floor but the problem is theres not much room to the sides of the car and the only place the motor can go once we get the car up is out the front and thats where the hoist is. so can i do somethin to hold the body up while i move the hoist to get the engine? let me know what i can do and if you have pics please post them.
Old May 27, 2009 | 06:52 AM
FlamingChicken's Avatar
theres a thread on camaroz28.com and maybe here that you can find where people built wooden stands out of 2x4 then placed there jack stands on top of that.
Old May 27, 2009 | 06:59 AM
Camaro-BMF's Avatar
Why are you pulling it out from the bottom???? go from the top, Much easyer
Old May 27, 2009 | 07:01 AM
z28rob18's Avatar
were takin it out the bottom figuring itd be easier to take the trans motor and the entire front suspension out at once. flamingchicken ill look into that its wat i was thinkin about. if anyone has pics or another idea keep em comin
Old May 27, 2009 | 07:49 AM
shbox's Avatar
Your opinion.
Old May 27, 2009 | 09:22 AM
tonskiguy's Avatar
Can't you just put some jack stands under the front frame rails and get the hoist out of the way? BTW, the bottom was easier for me.
Old May 27, 2009 | 09:25 AM
z28rob18's Avatar
the jack stands wont go high enough. so my idea is to take these 12"x18" bricks we have (dad does padios and retaining walls) stand a few and put the stands on them sound lik a plan?
Old May 27, 2009 | 09:36 AM
1993 z28 f1's Avatar
Hey:
I think wood would be a better choice than bricks. Bricks can crumble under load if not supported correctly, and that would be bad. I have seen it happen more than once even after somebody says don't do it. The guy did it anyway
and hit the brick lightly with the lift and the shock was all it took for the car to come down on the motor and lift and ruin it all, so be very careful if you try it, but I would use good wood over bricks or blocks anyday.
Dub
When In Doubt Do Without
Old May 27, 2009 | 09:39 AM
z28rob18's Avatar
alright. i figured those would be better then wood bein how thick and heavy they are but you make a good point
Old May 27, 2009 | 11:03 AM
sweetbmxrider's Avatar
take the car outa the garage!
Old May 27, 2009 | 11:56 AM
z28rob18's Avatar
its supposed to rain all week. i dont want it sittin out in the rain. and theres the same problem in the driveway unless i roll it down to the street
Old May 27, 2009 | 12:02 PM
tonskiguy's Avatar
Wood is best, but the bricks will work if the load is distributed on them properly like with a piece of plywood, the car is not that heavy with the engine and trans removed.
Old May 27, 2009 | 12:06 PM
ss.slp.ls1's Avatar
That's what I did. Not some shitty 2.5 ton jack stands though. I have a pair of 7-ton jack stands that I got from Autozone for like 40 bucks. When you max them out you should be able to sit the body on them and move the hoist out of the way.
Old May 27, 2009 | 12:15 PM
z28rob18's Avatar
good idea im goin to look for them i forgot about that
