Im not a mechanic i NEED HELP Leave FEED BACK PLZ
Originally Posted by lt1formula275
ok heres a story that might help i go to get in my 95 formula and i put the key in and it does nothing wont even turn over so put a switch in didnt fix it, turned vats off didnt fix it but finally i found a relay/fuse think behind the dash on the passenger side and hooked two pieces of wire together and it fired up but the secrutiy light is on but after 5 minutes of driving it goes away
anyone know about a relay fuse behind the dash if so 3 things
1. what should i be looking for
2. where exactley is it located at
3. once found what do i do ?
Start by describing what problem you are having. You don't just go jumping on whatever someone else's fix was, you have to do some troubleshooting.
Yes, there is a theft deterrent relay (TDR) to the right of the glove box.
Fix the relay to BCM connection (probably at the 4-pin relay connector); restore the use of the relay, and the fault light will go off and the car will starrt too!
