ram air or ls1 lid conversion?
Stock internal LTXs dont breathe enough to see a difference...hence the little to no power difference in a 58mm TB over a 52mm.
A big cam stroker is a different story, but if you are just a bolt-on LT1 a CAI is plenty, spend your money elsewhere.
Its the cheapest mod ive done. Used lid and a fernco. Thats all you need.
The LS1 lid swap is cheaper then most CAI while giving you the most gains. Even if you bought everything new you still wont spend near as much as an LT1 cai. Plus it looks cooler with a lid.
The gains of a lid are there, and they are real, but you need a big cammed stroker to see them, not a bolt on LT1.
I will be going to a lid setup myself on my stroker, and plan on testing the lid vs FIPK debate some more with dyno and track results on a much more potent LTX then my H/C stock shortblock
. The gains of a lid are there, and they are real, but you need a big cammed stroker to see them, not a bolt on LT1.
I got the Lid and Filter to fit under my Hood by cutting a little into the Core Support and setting the Radiator back a little, and cutting the understructure of the Hood a little bit.
I would believe the LS1 lid to be effective on a stock engine if one was going from a stock box to the LS1 lid, but switching from an aftermarket CAI, to a lid on a relatively stock engine I totally agree there would be no noticeable difference and there has been no proof as such yet.
That would be greatly appreciated!
.I guess the speed that the ram air kicks in is based on the frontal area of the ram air scoop, and the 100mph figure is really what is quoted on my crotch rocket...good for around 5hp at 100 and 10hp at 130
. Not sure why it does not state what the increase is at the top speed...my guess is that the gains become filter limited at a certain mph.None of that has to do with a lid really, since it is not sealed to a front facing scoop. Personally I plan on doing a lid conversion and sealing the bottom off, with two tubes leading into the fog light holes covered by the 1LE delete louvers. Similar to what one of the users here did(name starts with an "R" I think?). I think that would be a very trick functional ram air setup!
How cool would it be to track test a lid, a CAI, and the above ram air setup both for ETs and with a MAP sensor rigged in front of the filter(to remove it as a variable) to measure any variance from 2.5v to monitor positive boost or vacuum levels???
Man, Captain Mo' sure does get the brain juices flowing
