Oil cooler????
Old Jun 7, 2009 | 07:32 PM
1badzee's Avatar
Originally Posted by litch2004
but what i am saying is why do you actually have to remove this piece? If you remove the hoses and just leave the piece above the oil filter what will it hurt? If the only thing it does is circulates water around the oil passages going to the filter leaving it open wouldnt hurt anything. Well that is my own opinion. Maybe i am not realizing something that others are.
Please inform me of why you have to remove this piece and not just leave it there.
people who remove it mainly do it for more clearance with stepped headers.. Some headers (like LPP's or similar) will not fit/will have trouble fitting with the cooler in the way
Old Jun 7, 2009 | 07:48 PM
litch2004's Avatar
o ok. So if i remove the lines that run water through there i dont actually have to remove that piece...right? I have hooker LT's and i dont have any issues with my filter. Only the oil pressure sensor next to the filter.
Old Jun 7, 2009 | 08:05 PM
1badzee's Avatar
Then why remove the lines at all?
Old Jun 7, 2009 | 08:23 PM
litch2004's Avatar
just to clear up more room. Pretty much everything under the hood is gone now minus the engine. It would just be one less thing to have to worry about going bad or coming loose or whatever.
Old Jun 7, 2009 | 08:36 PM
1badzee's Avatar
Just delete it completely. If you remove the lines, the cooler will be no longer functional. Pointless to have it in there. Just remove it. It's too easy to do.
Old Jun 7, 2009 | 09:20 PM
94BlueZ28's Avatar
Just removed it tonight like you all said and yes there are 2 studs that need to be changed out with some regular bolts....I think I may have to run a larger filter as far as circumfrance! Looks to be a little larger, correct me if I'm wrong....Yeah I agrre that it is pointless to keep the cooler ecspecially sense I can't hook up the lines! My **** is blocked of on the water pump housing! I'll be plugging my radiator where the 2nd line hooked up...I'm good, i'll swap the 2 bolts out or cut them off with a dremel....Thanks again for everyone's input!
Old Jun 7, 2009 | 10:12 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I took mine off because it wouldn't fit with Kooks headers. I noticed improved oil pressure after removing the cooler and changing the filter.
Old Jun 7, 2009 | 11:09 PM
litch2004's Avatar
Do you have to fun a different style of filter?
Old Jun 7, 2009 | 11:18 PM
1badzee's Avatar
Nah, it's the same size filter.
Old Jun 8, 2009 | 07:23 AM
94BlueZ28's Avatar
Cool, I'll be swapping them studs out tonight and if I can't get them out i'm cutting them bitches off!
Old Jun 8, 2009 | 10:43 AM
1badzee's Avatar
That's the spirit!
Old Jun 8, 2009 | 11:54 AM
  #32
94BlueZ28's Avatar
Default your car
Originally Posted by 1badzee
That's the spirit!
Nice car by the way but the stocker wheels got to go!!!! Thanks for the help steve
Old Jun 8, 2009 | 01:08 PM
  #33
BTC's Avatar
BTC
Unless you're running headers that restrict the amount of room you have, you could probably run a longer filter with the cooler removed.
Old Jun 8, 2009 | 01:13 PM
  #34
94BlueZ28's Avatar
hooker super comp LT header's is what I'm running! I'll check it out when I mess with it tonight!
Old Jun 8, 2009 | 01:40 PM
  #35
1badzee's Avatar
Thanks. Car has draglites now. That picture is like a year old
