A/C Delete panel specs
Old Jun 6, 2009 | 06:52 PM
WhiteThunderZ28's Avatar
From: Your girls house, she is on my "D", Wisconsin
Default A/C Delete panel specs
Does anybody have the exact measurements for the A/C Delete panel?
I have some sheet metal and I want to make this panel before I put my engine back in.
Thanks
Old Jun 6, 2009 | 07:21 PM
Turnin20s's Avatar
Your probably better off to make a template out of some thin cardboard. Then trace it onto the sheet metal that way you get it right and don't have to worry about ruining a sheet of metal.
Just my opinion though, but I have a pic of the plate (think its from the merv's car) that I saved for reference.....
Attached Thumbnails A/C Delete panel specs-acdeletepanel.jpg
Old Jun 6, 2009 | 08:20 PM
litch2004's Avatar
That one is going to go on from the outside. here is a pic of one that goes in from the inside.
http://www.pcmforless.com/images/pro...s/fwdelete.JPG
Old Jun 6, 2009 | 09:18 PM
the_merv's Avatar
Yup, that's mine..
I had the Engine out of the Car and I used a really thin piece of Aluminum to make the Template. That Panel there is 1/16" Aluminum plate.
Here is another pic..
Old Jun 6, 2009 | 09:23 PM
blake110106's Avatar
does anyone sell them? Im deleting my a/c also!
edit: NM I found one from BMR
http://speed-eng.com/store/bmr-delete-panel-p-9622.html
Old Jun 6, 2009 | 09:35 PM
Turnin20s's Avatar
Yeah but the ones that are sold bolt to the inside requiring you to remove the heat too. The one like the merv has keeps the heat so you can still defog the window and stay a little warmer when it gets cold. But looses the AC and makes the eingine compartment look 10000000000x better LOL
Old Jun 6, 2009 | 09:40 PM
Black94Z28's Avatar
I used the gasket as a templete. I have pics of it in my build thread, maybe page 4 or 5? Just used some sheet metal from menards
Old Jun 6, 2009 | 09:58 PM
the_merv's Avatar
Trust me the heat is nice..
Old Jun 6, 2009 | 10:21 PM
You took the template off correct? If so, you just chisseled the welds off?
I have to put a piece of metal on the bottom right corner by the tranny, I found a nice rust spot there.
Old Jun 6, 2009 | 10:43 PM
the_merv's Avatar
Here is a current pic with mine installed..
Another major thing too was I got rid of the stock Heater Lines and used some 5/8" & 3/4" Rubber Hose with a Bracket off of the Strut Tower. Doing it that way really opened up a ton of room.
