Grinding calipers Need help now please!
Old Jun 9, 2009 | 09:42 PM
AChotrod's Avatar
Default Grinding calipers Need help now please!
Im puttin on a new set of drag rims/tires and grinding the calipers right now. How much clearance is needed??? Need help asap!
Thanks
Mike
Old Jun 9, 2009 | 09:45 PM
Black94Z28's Avatar
Thanks
Mike
Just did mine friday, not much is needed, just the edges. I see your chicago area, i work in mount prospect, live in mchenry, you can check out how much i took off if you want. I ran 15x3.5s and 15x10 prostars. cell is 309-678-9949
Old Jun 9, 2009 | 10:00 PM
AChotrod's Avatar
Im running Greg Welds front and back. With my old prostars I didnt need any. I want to know how much space is needed. If it doesnt hit its fine or is there a amount of space needed?
Old Jun 9, 2009 | 11:03 PM
robsquikz28's Avatar
just enough to spin the wheel by hand and if it dont rub at all then your good
Old Jun 10, 2009 | 10:36 AM
96blackta's Avatar
My friend did this a few months ago and just yesterday his rear-right caliper exploded. It's literally a twisted, mangled mess and it blew a hole in his Z06 rim.
Old Jun 10, 2009 | 11:42 AM
AChotrod's Avatar
Thanks Rob.
I dont think Ive taken enough off to make it twist/explode and this car see's very limited street use. When I can afford it Strange drag brakes will be put on. So maybe a month or 2. Im not too worried about it.
Old Jun 10, 2009 | 01:16 PM
Formula383's Avatar
I was told to take duct tape and place over the edges of calipers. When the wheel spins freely without touching the duct tape, you should be good. Don't forget to remove the duct tape...
I only had to do the fronts and I used a hand file. Took about an hour to do both sides.
Old Jun 10, 2009 | 01:28 PM
myltwon's Avatar
camaroz28.com has a good writeup sticky in the wheel and tire forum
Old Jun 10, 2009 | 03:19 PM
AChotrod's Avatar
we have one here also but is for ls1s
Thanks for the idea Kyle Duct tape thickness it is!!!
Old Jun 10, 2009 | 03:55 PM
the_merv's Avatar
I only had to do my Rears for my Draglites.. I just had the grind off the little fin looking pieces on the Caliper. I used a Dremel and a Burr..it took about 15 min a side.
I have LS1 Brakes on the front and I'm using 1/4" Wheel Spacers with my 15X4's.
Old Jun 10, 2009 | 04:04 PM
AChotrod's Avatar
Im using these Rims They are different than the prostars or draglites on the inside.
The fins are done its the back side of the caliper, thats needs alittle more work. Just needed to know how much space inbetween the rim and caliper is needed.
Old Jun 10, 2009 | 04:10 PM
i told ya already man just enough to spin the wheels without it rubbing at all, if thats good your good...make sure you tighten the lugs when you spin the wheels to prevent them from wobbling on the axle, duct tape, anti seize or rubbing compound you just need something to leave a mark on the rim but mainly you can hear it grind if its rubbing...
Old Jun 10, 2009 | 04:33 PM
AChotrod's Avatar
I got the answer already. Thats exactly what im gonna do Rob. Im stuck at work untill 8.
When I left it lastnite it looked like it wasnt touching or just barely touching, but the rim wouldnt spin, so I need to check out the back side of the tire when I get home and see why.
Old Jun 11, 2009 | 10:08 AM
Black94Z28's Avatar
The wheels are going to look awesome on the car. Pics please!
Old Jun 11, 2009 | 11:46 AM
AChotrod's Avatar
Got one done lastnight and it looks killer!! Just like the rim/tire combo was made to fit the car!!
Lots of grinding but the caliper still looks plenty strong, so Im not to worried about it breaking.
Ill get pics up once they are both on.
Old Jun 11, 2009 | 12:31 PM
the_merv's Avatar
Old Jun 11, 2009 | 12:39 PM
AChotrod's Avatar
I Work untill 8 get started on the car about 9 so it doesnt give me much time to be loud in the garage after work. Ill try and get the other on tonight and pics asap.
Old Jun 11, 2009 | 02:21 PM
I8ASaleen's Avatar
or
Old Jun 12, 2009 | 10:26 PM
AChotrod's Avatar
Here some pics, springs still need to settle a bit.
Old Jun 12, 2009 | 10:33 PM
SPEEDYTRANSAM1996's Avatar
god damn that thing looks sexy NOW
i know im late but thats what i did when i had prostars on my car.
