Big timing chain problem
You should do a thorough investigation as to why your chain broke.
It wouldn't hurt to get a Cloyes double roller. But you will have to delete your relctor ring and tune out the cps code. You also have to run an EWP to use the double roller. Not to forget you have to clearance the inside of your new timing cover a little. Since you need a new one, it would be best to get a '95 cover that does not have the hole for the CPS sensor.
And as previously stated in this thread make sure that you find out what caused the chain to snap and make sure the engine isn't damaged.
The remedy was the sooper dooper oversized crank gear which then yielded about .020 clearance between the cam and crank gear...
