opti spark question
Old Jun 16, 2009 | 11:39 PM
kalebm22's Avatar
Restricted User
Default opti spark question
when an optispark fails do you need to replace the full distributer or will the cap and rotor fix the problem?
Old Jun 17, 2009 | 05:35 AM
MyOlina's Avatar
I'm pretty sure if the actual distributor goes out it gives you a check engine light. If you are just having hesitation, staggering, misfiring symptoms than you can probably get away with just the cap and rotor. I actually just got finished replacing my cap and rotor last night. I had no check engine light coming on and the cap and rotor seemed to do the trick. Just to do the cap and rotor you will need an e4 external torx and a t8 torx.
Old Jun 17, 2009 | 06:40 AM
Badazz 97 TA's Avatar
i disagree. most will tell you to replace the whole thing. yes the cap and rotor do wear over time but the opti sensor itself is the culprit for most problems, not the cap and rotor
Old Jun 17, 2009 | 07:44 AM
shbox's Avatar
It depends on what the problem actually is. If the opti is a high mileage one, you are probably better off replacing the whole thing.
Old Jun 17, 2009 | 11:37 PM
dirtynorth's Avatar
Mine only messes up and misfires when its wet outside any other time its fine except for a little bit of a rough idle. Which i think is caused by my recent emisisons deletes. But im not sure. Should i replace the whole thing or just the cap and rotor do you think??
Old Jun 18, 2009 | 12:51 AM
Z28Camaro30Ann's Avatar
Did you delete the emissions only, or did you tune it out of the computer too? And I was having huge misfire problems and all MULTIPLE times.
First time turned out to be the SP wires hitting the header...
Second time was the Cap and Rotor...
Third time was SP Wires again...
Fourth time was the distributor...
Fifth and final time was the SP Wires...
This all happened within a month and a half...
I ended up saying F it and went with the MSD Distributor, MSD Cap/Rotor, and MSD 8.5mm OTVC SP Wires. Been 2 months now and NO problems whatsoever!
Old Jun 18, 2009 | 04:37 AM
RamAir95TA's Avatar
I second replacing the whole thing. Many times it is difficult to tell what the culprit is when one starts failing.
Old Jun 18, 2009 | 06:07 AM
MyOlina's Avatar
So it doesn't give you a check engine light when something is wrong with the sensor ? I wonder why i was told that...grrr
Old Jun 18, 2009 | 11:11 AM
I got a check engine light but it wasnt for any sensors...it kept telling me I was getting a P0300 "Random/Multiple Cylinder Misfire" when my capand when my distributor went out...when I burned through the SP wires I got a P0305 "#5 Cylinder Misfire"
Those were the only SES lights I got
Old Jun 18, 2009 | 12:29 PM
ss.slp.ls1's Avatar
P0300 and P0336 can be caused by a bad opti or a bad coil or both.
I agree with those who said to replace the whole unit. Make sure you get a genuine AC Delco/Delphi opti.
Old Jun 19, 2009 | 11:46 AM
kalebm22's Avatar
Restricted User
well i replaced the opti with an accel distributer, and it fired up a little rough but then it idled good and ran better then ever. but after i turned it off the car had trouble starting and acted like it wasnt getting enough fuel. what would be causing this? bad fuel filter maybe?
Old Jun 19, 2009 | 11:57 AM
well you bought a crappy brand opti. accel is garbage
Old Jun 19, 2009 | 12:00 PM
ss.slp.ls1's Avatar
^Agreed.
OP, If you suspect a fuel issue, test your fuel pressure.
Old Jun 22, 2009 | 09:40 AM
jcleaver17's Avatar
made the mistake of buying an opti from autozone, now after changing it 3 times in a year, i went down and got an O.E. opti... see how that goes
