radio and power window turn off while driving.
Old Jun 17, 2009 | 04:29 AM
killagt's Avatar
Default radio and power window turn off while driving.
My driver side window stop working last couple day, and today some how while driving, my radio turn off and my passenger side window is do not work. I let it sit for about 1 hours and it working again ?
Old Jun 17, 2009 | 09:53 AM
trippinholyman's Avatar
motor burnt out probably. when they start to go, they work slower and overheat - after they cool off for some time, they will work a little and then overheat again - usually they overheat when they encounter some resistance. so it will never be able to roll all the way up because the most resistance is at the top of the travel.
http://shbox.com/page/windowmotor.html
you say your radio turns off? does it turn off then on? mine does that sometimes but only when i playing the music REALLY loud with something like lots of bass etc, i assume its overdraw or something like that and the radio always reboots. i turn the music down and bass and treble or w/e down also and change the song. certain frequencies it seems, mostly when its really hot out. i heard it could be a bad ground issue, i did the radio install myself. perhaps you have a wire loose in the harness somewhere? our radios are easy to get to, so check your harness and wiring.
Old Jun 17, 2009 | 10:26 AM
sweetbmxrider's Avatar
being a 97, i would look into the bcm, body control module. have it scanned by a shop if you can.
Old Jun 17, 2009 | 05:39 PM
NemeSS's Avatar
sounds like bcm issue. usually the pass side door window and electronics will not work and radio will shut off all of a sudden
Old Jun 17, 2009 | 11:38 PM
killagt's Avatar
YES you got it, what the hell is BCM ?
Old Jun 18, 2009 | 12:56 AM
Schweet97Z's Avatar
Had the same problem on my 97 Camaro. BCM was shot...
http://shbox.com/1/4th_gen_tech2.html#bcm
Old Jun 18, 2009 | 12:58 AM
SPEEDYTRANSAM1996's Avatar
Fairly common problem -- it's mostly likely a bad BCM, or a loose power and/or ground connection from the BCM.
BCM location can be seen on Shoebox's website....or I think BFrankers as well under alarm install.
Usually hitting to the right of the dash will help since that is near the BCM.
But its in pass.side kick panel
Old Jun 21, 2009 | 09:11 PM
97Z28SS's Avatar
This has just started happening with my car except the drivers side window motor burned out and I just had that replaced and now my dash lights and radio lights go out whenever the lights are on. Is this the same problem?
Old Jun 21, 2009 | 09:24 PM
97camaross's Avatar
it is your bcm if you wanna fix it for free take it apart and resoder the soder dots that are in the shape of a T if that makes any since. they are notorious for getting small cracks there. i did it to mine and it worked
Old Jun 21, 2009 | 11:03 PM
I8ASaleen's Avatar
On a 97 it's right up under the driver's side kick panel along with a buttload of electrical connections.
Old Jun 21, 2009 | 11:20 PM
killagt's Avatar
my driver side window burn too. I have same problem as u, but my only happent once, and for the last time it happent, it have not happent yet.
Old Jun 22, 2009 | 12:39 AM
BIG_T's Avatar
Old Jun 22, 2009 | 01:30 AM
madhatter's Avatar
https://ls1tech.com/forums/general-l...blems-fix.html
Written for an LS1 but you get the idea.
Old Jun 22, 2009 | 09:48 AM
killagt's Avatar
any one know where I can buy a good power window motor ?
Old Jun 22, 2009 | 01:25 PM
Spooky. My car is a 96 and just started doing this today.
Old Jan 22, 2013 | 09:46 PM
Marco Lopez's Avatar
How does the bcm look like
Old Jan 23, 2013 | 08:26 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Don't "fix" the window motor until you've done the BCM mod.
This is a common problem with these cars. Get the the BCM, it's above or next to the glove box. Crack it open and touch up the solder joints on the circuit board. As noted above, it's usually the larger joints that hold the relay to the board.
Put it back in and your problems will be gone.
GM has always had a problem with cold solder joints. Wiper control boards, BCM boards, ABS modules, etc.
Old Jan 23, 2013 | 12:45 PM
1995blacktattop's Avatar
FWIW if anyone with a 93-95 ever has this happen, it's due to the RAP module under the steering column. had this happen on mine last year while wiring in the auto trix pass window fix. i accidently hooked up the wrong wire (gray instead of brown i think) and it fried the module and i lost the radio and the power windows.
Old Jan 23, 2013 | 03:00 PM
02v8ta's Avatar
Alright I'm going to say it...
.... 2009.
Old Jan 24, 2013 | 01:06 PM
Max78's Avatar
.... 2009.
At least they used the search function!
THATNK YOU! I have been looking for my intermittent radio/window problem. Now I know what it is, cold solder joint and overheating passenger window motor.
