radio and power window turn off while driving.
Like already stated taking out the bcm and fixing it yourself is the best solution. I think with mine I was just able to re soder what was already there. Deff didn't look pretty but worked
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
FWIW if anyone with a 93-95 ever has this happen, it's due to the RAP module under the steering column. had this happen on mine last year while wiring in the auto trix pass window fix. i accidently hooked up the wrong wire (gray instead of brown i think) and it fried the module and i lost the radio and the power windows.
well the radio turns off becasue the the wire is not the right size, for the loudness you want to to turn up.
some times u take the door pannel off and beat on the window motor it will work again, to stop it from over heating u play with the slidder pad against the window. move them in alittle bit , play with the window up and down watch how it closes. that helps it roll up and down
