timing chain
Old Jun 17, 2009 | 09:14 PM
reaper97's Avatar
Default timing chain
would this kit(Cloyes Gear C-3039) be a good choice for a timing chain set?thanks
Old Jun 17, 2009 | 09:58 PM
Elliott's94Z's Avatar
I've always been a fan of the stock replacement. Work well.
Old Jun 17, 2009 | 10:43 PM
1eyedmaro's Avatar
i have that chain. Nice piece and real tight
Old Jun 18, 2009 | 06:08 AM
reaper97's Avatar
anyone else use this chain?
Old Jun 18, 2009 | 03:53 PM
reaper97's Avatar
Old Jun 18, 2009 | 04:09 PM
ss.slp.ls1's Avatar
Cloyes Gear 9-3145
^^^I believe that is the one you want. You will have to delete your reluctor ring and clearance the inside of your timing cover also.
Old Jun 18, 2009 | 05:04 PM
reaper97's Avatar
Originally Posted by ss.slp.ls1
Cloyes Gear 9-3145
thats all i have to do on my 97 style timing cover for this timing set to work??
Old Jun 18, 2009 | 05:22 PM
RallyBoy's Avatar
It is what I used for my 97 SS. So far so good.
Old Jun 18, 2009 | 05:23 PM
reaper97's Avatar
how many miles do u have on it? did u have any problems installing it?
Old Jun 18, 2009 | 05:41 PM
ss.slp.ls1's Avatar
I forgot that you need to use an EWP as well, but same goes for the C-3039.
As far as stock timing set durability goes, breakage is very rare. If you want to go with a more durable aftermarket timing set, might as well get a double roller...
Old Jun 18, 2009 | 06:50 PM
reaper97's Avatar
I have a ewp going on the new motor...
Old Jun 18, 2009 | 09:49 PM
1eyedmaro's Avatar
not sure if you are meaning that you have to use an ewp with the c-3039 or not, but just to clarify things you dont have to. It is built for the LT1 and has the water pump drive gear on the backside of it.
Old Jun 18, 2009 | 09:52 PM
reaper97's Avatar
im going to use a ewp
Old Jun 19, 2009 | 02:30 AM
ss.slp.ls1's Avatar
Oh, didn't know that. I'd still tell him to get the double roller since he's running an EWP.
Old Jun 19, 2009 | 02:32 AM
1eyedmaro's Avatar
definitely
Old Jun 19, 2009 | 02:35 AM
reaper97's Avatar
Thanks for your guys help
