Turbo Setup
Old Jun 18, 2009 | 06:20 PM
palt1z28's Avatar
Default Turbo Setup
Well ima be off to basic training this wk coming up and ima start this post so when i come back I can make my car a bit faster.
Already have a 68mm garrett turbo( small i know)
Looking to buy another 68mm
Thinking of going Twin turbo.
What do you guys think? Anyone have any ideas for heads/cam/pistons.
Frontmount? is it possible. or better to go rearmount?
Another thing that came to mind, is it possible to do somewhat of a feeder turbo, like a 68mm feeding a 90 or something like that. I am not much of a tech guy so fill me in.
Any ideas post up or let me know
Old Jun 18, 2009 | 07:15 PM
Anthony0908's Avatar
Ya I dont know much bought it I think its called twin scroll when one feeds another. The lancer does that or something like it.
Why not just get one single? Its twice as much pipe for a TT and they make less power. But im a fan of turbo so what ever you do Good Luck
You also know you will need more than just the turbo piping ect.
The car its self will need supporting mods. Ide go to the boosted section post there and read allot.
Old Jun 18, 2009 | 07:21 PM
MUSTANGBRKR02's Avatar
NO setup makes less than another if both set up properly. With room being the main issue single seems to be the norm. But if the numbers in your sig are good numbers ride that out and get some times then spray it and go faster. Going in to the service you will not make alot, but if you are smart with your money and choices you can leave after your time with some great choices, jobs and finances in order.
Old Jun 18, 2009 | 07:45 PM
I disagree a proper single will make more than proper twins.
I think a turbo will be better than spray.
Old Jun 18, 2009 | 10:50 PM
myltwon's Avatar
your 11.5:1 LT1 makes 460rwhp through a 9" and a mailorder tune?
Old Jun 19, 2009 | 12:13 AM
palt1z28's Avatar
no its been tuned since the mailed one
Old Jun 19, 2009 | 12:41 AM
Schweet97Z's Avatar
sterling...stop bs-ing with your numbers...there is a difference between dyno queens and cars that can et. you dont want that car to be like a supra! your car runs so good. get the box for the nitrous and let it rip!
the numbers i believe were like 420 n/a and 560 on a 150 shot. The car has power. just get it to the ground.
Old Jun 19, 2009 | 10:29 AM
blackhawk400's Avatar
a 68mm might work good for a rear mount setup on the 383. maybe. check out the FI section.
twins, it might be too big, plus theres all that mess of piping everywhere, 2x as complicated IMO.
from the research i've done, twins will build boost quicker and higher through the rpm range but max out lower, while a big single will take longer, but build higher top end power and max out higher.
Old Jun 19, 2009 | 11:14 AM
ClovisAutoMotion's Avatar
All of the Pro Mod and door slammer cars that were once Big singles are switching or have already switched to Twins. Between 2 turbos that move the same amount of air as a large Single will, the single MIGHT make more power on top but the twins will make more average power. But like MustangBRK said they both have to be done properly.
twin 68's is by no means small. My build is twin 60mm turbonetics 60-1's on a 383 and it should have no problem making 650-700rwhp. Package is going to be a pain but I've always wanted to do a front mount kit like INTMD8's red SS.
do you want to keep all your accessories?
Old Jun 19, 2009 | 12:19 PM
palt1z28's Avatar
do you want to keep all your accessories?[/QUOTE]
what to you mean by that.
keep the posts coming
Old Jun 19, 2009 | 12:51 PM
A/C, power steering, alternator in the stock location.
Old Jun 19, 2009 | 03:23 PM
myltwon's Avatar
turbo setups can be unforgiving to stock accessory locations
Old Jun 19, 2009 | 07:17 PM
palt1z28's Avatar
As of now i have an A/C delete pulley(no heater or ac in car)
and yes i would like to keep the power steering/alternator in the stock location if possible.
Old Jun 19, 2009 | 08:55 PM
Purple95Z28's Avatar
I would talk to the guy who runs lt1boost.net if I was going to be trying a turbocharged setup. He makes some nice plumbing for people who want to retain AC, PS, etc. You will have to stand the radiator up among other things at the very least though.
Old Jun 20, 2009 | 11:08 AM
The A/C delete frees up a lot of options and space. Realquik's Single systems are great, but I don't see how you could put filters on the twin kit without choking airflow.
