Need master tech advise
Old Jun 18, 2009 | 09:40 PM
monchis's Avatar
Default Need master tech advise
I need a camaro master tech (lt4) please help!!
HEY GUYS I REALLY NEED SUM HELP, ONE OF MY HOSES CRAKED OPEN TODAY SO ALL MY ANTIFREEZE FELL OUT...MY CAR HEATED UP AND I PARKED IT RIGHT AWAY...I REPLACED THE HOSE FILLED IT WITH ANTIFREEZE CRANKED IT UP AND IT STILL KEPT HEATING UP... I CHEKED THE RADIATOR TO SEE IF IT WAS CLOGGED AND IT HAS WATER FLOW FROM ONE SIDE TO THE OTHER...THEN I REMOVED THE THERMOSTAT TO SEE IF THAT WAS THE PROBLEM AND IT STILL IT KEPT HEATING UP...THE RADIATOR IS FULL OF WATER AND ANTIFREEZE AND STILL IT HEATS UP RIGHT AWAY...THE ONLY THING THAT I CAN THINK OF NOW IS THE WATER PUMP NOT WORKIN BUT I DONT KNOW HOW THAT WOULD HAPPEN IF IT RUNS WITH THE CAMSHAFT??
IF YOU GUYS HAVE ANY SUGGESTIONS I WOULD REALLY APPRECIATE U ALL'S OPINION THANKS ALOT...
Old Jun 18, 2009 | 09:42 PM
transamws6_97's Avatar
probably have air in the system try using the two screws on the cooling system to release any air that is traped in there
Hawk40's Avatar
when you put the new hose on you got air in the system...start it..run it to operating temp...then open the bleeder screw by the thermo housing...let it bleed it until solid coolant comes out..close it up..you'll be good to go
ohh and be careful not to let any coolant drop down onto your opti
Old Jun 18, 2009 | 09:51 PM
monchis's Avatar
Whats the opti
Old Jun 18, 2009 | 09:53 PM
monchis's Avatar
But i release those screws and no coolant comes out
monchis's Avatar
Well a little coolant came out but it was more air
Old Jun 18, 2009 | 09:54 PM
monchis's Avatar
And the car is still heating up
litch2004's Avatar
Originally Posted by monchis
Whats the opti
The opti spark distributor. It is under/behing the water pump and behind the crank pully
Old Jun 18, 2009 | 09:58 PM
monchis's Avatar
Oh ok, so what if the two screws arent bleeding properly, what could be wrong??
Old Jun 18, 2009 | 10:01 PM
monchis's Avatar
Just a lil bit of coolant pops out, like very little
Old Jun 18, 2009 | 10:02 PM
monchis's Avatar
And i left my thermo off, but i dont think that could be affecting it, it seems as if the coolant is not passing to the blok i think...
Old Jun 18, 2009 | 11:22 PM
shbox's Avatar
You just have air in it. If you don't do it right from the beginning, the air can be hard to purge.
Read the refill info, here: http://shbox.com/1/4th_gen_tech2.html#radflush
Old Jun 18, 2009 | 11:24 PM
1badzee's Avatar
If there isn't a steady stream of coolant coming from either bleeder screws, there is still air in the system.
Old Jun 18, 2009 | 11:46 PM
1993 z28 f1's Avatar
Hey:
As stated before you have to bleed all the air out, not just some or a little, all.
This may take some time and multiple bleeds to get it all out.
follow shbox's directions till only coolant comes out and no air, remembering to
keep rags away fom the belt but protecting the opti below the water pump.
Dub
When In Doubt Do Without
Old Jun 19, 2009 | 03:21 PM
monchis's Avatar
i already did the procedures...it's been at idle for about 10 min and temp is good...do i need to run it longer??
Old Jun 19, 2009 | 04:06 PM
shbox's Avatar
If it is up to temp and there is no more air coming out of the bleeders, then you should be good to go.
Old Jun 19, 2009 | 04:09 PM
monchis's Avatar
yup, thanks a lot guys i think its good to go... im kinda new to camaros thats y...special thanks to SHBOX for the good procedures...
