LE2 Dyno results.
Old Jun 23, 2009 | 05:41 AM
Bersaglieri's Avatar
Originally Posted by SS RRR
Why such overly huge injectors?
I always read you need to run your injectors around 85 percent duty or a little less. He is requiring about 32-33lb of fuel for his approximate 475fwhp, assuming around 15 percent drivetrain loss. 38lb injectors running at 85 percent duty is around 32lbs. So what's overly wrong with them? What are the harmful effects of running a slightly larger injector, other than it running more smoothly, efficiently, and reliably?
Originally Posted by speed_demon24
It's illegal to move the location of the cats which makes longtubes are illegal in 50 states.
Unless he doesnt live in the 50 states, lol.
Originally Posted by za355tx
Yeah def with an electric wp you should either hit 400 or be very close. Not bad at all for a relitively small cam. Nice job.
Yes, a few small things would push you over 400rwhp.
By the way, pretty nice numbers for an emissions cammed setup. Props to Mr. Elliot and the owner.
-Dustin-
Old Jun 23, 2009 | 07:47 AM
airfix's Avatar
-Dustin-
Thanks man.
Old Jun 23, 2009 | 07:48 AM
airfix's Avatar
Originally Posted by roadtrip120
Mail order tune or did you or someone else mess with it on the dyno??
Dyno A/F and spark advance??
Peak numbers dont tell who is going to win a race
Ill post all that stuff along with the dyno Graph when I get home from work.
Old Jun 23, 2009 | 08:27 AM
Whyrun's Avatar
I don't know about moving the cats around making it not emmissions legal, the inspection guy told me as long as their there it's in spec, And I wouldn't think that moving them to a diffrent location could change the emission's output as long as they were close enuff to the header to heat up enuff to work correctly..
Old Jun 23, 2009 | 09:24 AM
SS RRR's Avatar
Village Troll
Originally Posted by 1badzee
I have 42's lol. Then again I will be spraying a healthy shot of the ****
Wet or dry kit?
flywheel hp X .007= minimum acceptable injector size.
So assuming the dyno is accurate, 450 flywheel hp X .007= 32#
There's nothing wrong with going that large. It's just not necessary.
Old Jun 23, 2009 | 10:06 AM
hotrodscrap's Avatar
Tune?
Maybe a stupid question, is it a daily driver? If not so much, then try a 1LE a/c delete pulley.
-SS
Old Jun 23, 2009 | 11:12 AM
AChotrod's Avatar
Great numbers with an emissions cam! Im sure with a bit of tweaking youll get to 400!!!
My stock clutch looked fine when I took it out and survived many 4k plus dumps but would slip just enough to keep the rear alive at the track. Im sure if I still had the stock rear and my street twin it would snap like a twig.
Old Jun 23, 2009 | 06:54 PM
NightTrain66's Avatar
LS1TECH Sponsor
good job at the dyno.
Pretty good #'s for a 223/230 112 LSA duration cam.
Not sure how most states are on inspection but most local guys are just worried about the "sniff test" and alot less on the if tghe cats have been moved to a different location.
Probably depends on the state and the person doing the inspection.
I am sure it is a blast to drive.
Lloyd
Old Jun 23, 2009 | 07:03 PM
airfix's Avatar
ya it is tuned, Vince from trefica tuned it, super nice guy, it is a daily driver, and I have the a/c delete pulley on it.
Thanks alot for all your help lloyd, The car is So fun to drive an awesome jump from when it was a bolt on car a few weeks ago.
Thanks
Old Jun 23, 2009 | 07:05 PM
airfix's Avatar
I hope I have as much luck with mine as you did with yours, atleast until summers over but im not holding my breath.
Old Jun 23, 2009 | 07:23 PM
ss.slp.ls1's Avatar
As long as you are tuned for the injectors you're fine. I have 39# injectors on my cam-only 350. They were a steal and they leave room for more mods.
+1 on what NightTrain66 said, many states only care if you pass the sniffer and have no codes, other than that there's no worries.
I live in CA, not so lenient...
Old Jun 23, 2009 | 08:14 PM
  #32
My95Z's Avatar
Thanks
A dyno tune would easily put you over the 400 mark. Still good #'s especially for emisssions cam and mail order tune.
Old Jun 23, 2009 | 08:38 PM
  #33
airfix's Avatar
It was a dyno tune. I went a cross the border to get it dyno tuned by vince, Because no one in my area could tune my car. I had a mail order tune from a nother tune but it was way off. he didnt do anything I asked for in the tune, the car ran terrible. Now it runs MUCH better. Vince was a great guy to deal with.
Old Jun 23, 2009 | 08:55 PM
  #34
1badzee's Avatar
Wet or dry kit?
250 wet lol
Old Jun 23, 2009 | 08:56 PM
  #35
Chevy053's Avatar
I am really curious to see what the dyno graph for this looks like. Its essentially the same setup I was planning on going with soon.
Old Jun 23, 2009 | 09:59 PM
  #36
airfix's Avatar
I'll post it up shortly sorry I havnt yet.
Old Jun 23, 2009 | 10:09 PM
  #37
wrd1972's Avatar
Tighten up and get'r posted
Old Jun 23, 2009 | 10:53 PM
  #38
speed_demon24's Avatar
250 wet lol
So why do you need 42lb injectors then?
Old Jun 24, 2009 | 05:29 AM
  #39
I hope the injector police dont find out I have 44lb injectors
That's a pretty small cam to be making that much at the wheels. Well done.
-Dustin-
Old Jun 24, 2009 | 07:14 AM
  #40
LS1 SPEED's Avatar
nice results
I'm sure you will meet your 400+ rwhp goals with a few tweaks.
