LE2 Dyno results.
Okay, I will be the average Joe just trying to contribute to discussion with the facts I have on hand.
The other guy can be the infallible & righteous bastard who cant post a thread with inflaming others or acting an ***. I doubt I will need the help on this one if you one bases the decision on past history and posts.
Nothing was said about AI/LE anything in this thread. That is on all of you. I have no AI parts on my car. I am a Lingenfelter fan or nutswinger or whatever you deem the best title.
It'll be interesting to see what the pool is about 5 more years down the road. A 9" will then net a 30rwhp loss, LT1's will be dynoing 500rwhp and running 13's...
To the OP- Great job on the dyno numbers. If you have a track and like to race then focus more on what improvements you can do ET wise and don't worry about reaching a 400rwhp mark on a dyno. If you don't have a track then I'm sorry.
simply because he stated that the car might make 15+/- rwhp with a factory rear doesn't seem out of the question
car craft even had a decent article on a similar subject comparing an AOD backed motor with a 9" vs a Muncie 4 Speed backed motor with a 12 bolt. the AOD/9" car had around 36% average parastatic loss vs the M4/12 Bolt car that had around 18%. heavy duty rears and strong autos eat power
Yep thats what I said. I believe that if I had the 10 bolt I would make 400RWHP on the dyno. With the heavy 9" ring and pinion and the Detroit Trutrac, I believe there is ~15RWHP of loss WRT my setup.
Its documented (with actual numbers) by others that they lost similar amounts of power when they went with the Dana 60 from the 10 bolt. And from what I have read here and elsewhere, the 9" robs more power than the Dana due to the lower pinion and greater tooth contact. And I am still erring on the low side and manage to get SS RRR's panties all wadded up.
Oh **** there I go with the facts and reasonable assumptions again.
yes I know differential loss is no where near a new topic, just using a current and relevant article for a point of reference
To the OP Good luck at the track.
... I'd be willing to hear the story on Kenny Thomas...
-Dustin-
.In the LTX case besides just happy dyno's I think a lot of cars are just set up poorly. Too many people don't get the right supporting mods or are brainwashed into the "stock is good enough for 10's" mindset. They through together their 425rwhp car and then run with full stock suspension and street tires while babying their 10bolt...then end up with worst times then a bolt-on LTX with slicks, full suspension, and a 12bolt would run.
It is a shame though that so many shops put out inflated dyno numbers to make their parts/labor/tuning look better. It happens all the time with crotch rocket shops too - my bike curiously dyno'd only one single hp more after a race filter, full exhaust, and a tune then it did with just a muffler when it should have been an easy 10-15hp more
I want to say I bought my Strange in '99 but it could have been in '00. I sold it in '01 before I sold the car. The stock rear is in there now.
