LT headers question
Old Jun 24, 2009 | 01:14 PM
nolimit5685's Avatar
Default LT headers question
Would someone be so kind to tell me the pros/cons to LTs that have/don't have emissions? Here in IN I can get away without emissions however I don't know the difference. I am wanting to go with probably Pacesetter LT to a true dual. My car is pretty much a dd that I baby. Thanks!
Old Jun 24, 2009 | 01:20 PM
halucinator's Avatar
Headers that don't have Emissions have no provisions to hook up the AIR or EGR. So you can delete those since you live in Indiana. I did. Unless you live in lake county then you can't get away with it.
Old Jun 24, 2009 | 01:23 PM
i understand what emission free headers are, but what is the benefit to deletion of the emissions from the exhaust? ie "race headers" and i live in indy
Old Jun 24, 2009 | 01:38 PM
93cz28's Avatar
when u delete the AIR, that is just to heat up the 02 sensors quicker, and the EGR is exhaust gas recirculation, whe you take that off you dont get exhaust gases recirculating back into your intake.
Old Jun 24, 2009 | 02:33 PM
ss.slp.ls1's Avatar
There is no con to deleting the emissions crap and the pros is to clean up the engine bay and keep exhaust gas from entering the intake. That's why I got race headers (non-emissions). You will need block off plates for the back of your intake manifold and some vacuum caps for the ports on the side of the intake.
Old Jun 24, 2009 | 02:53 PM
what all can be deleted/removed from the engine bay when doing race headers?
Old Jun 24, 2009 | 04:00 PM
ss.slp.ls1's Avatar
The AIR pump, vacuum solenoid, EGR valve, EGR tube, EGR solenoid, and while you are at it...EVAP solenoid and EVP purge solenoid. Use block off plates on the back of the intake manifold and cap off all vacuum ports that are not being used anymore. Search for threads on cleaning up the engine bay or deleting emissions and you should find lots of info.
Old Jun 25, 2009 | 07:00 AM
thanks much! i'll look.
Old Jun 25, 2009 | 07:33 AM
Forgot to mention a pro is that some have said that the EGR is a possible culprit to the intake leaking on the rear seal.
