Oil pump screen install
what i did was put the oil pump between my legs while kneeling down. then positioned the pickup tube where i wanted it in my left hand while holding a 3/4in wrench above that flared lip. i then hammered with my right hand on the wrench. it took a few good wacks for it to finally go in the pump. once i hammered it in about half way i made sure the tube was angled correctly. then hammered it all the way in.
How much you heat something is a guessing game. If it is something I am worried about damaging or if it will be sliding into a seal while hot I boil it in water to limit heat to about 212f, put the other part in the freezer for an hour or two.
Never done it with an oil pump pickup but have with a lot of other parts.
