Need help setting up roller rockers
I installed the rockers as instructed by the head porter, tighten them on the backside of the lobe untill they cant be pulled off the valve, go a quarter turn more, then set the allen screw inside the rocker stud. I did thid for all the rockers, and went on to other work..
Later, I looked over them again to double check my work, and found all the rockers on the backside of the lobe were very loose. So I went over all the rockers again. Now I realize that all I did was collapse the plungers, and once there is oil pressure, the rockers will be way too tight......
So what the hell do I do now?
http://www.youtube.com/watch?v=VPOaAsuzhsE
Also, shoebox has other methods of adjustment:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
I removed all of the allen set screws (because I didn't want any of them vibrating out if they were loose) but I keep the adjustment that I had before I started the car.
Started up the car (yes you can run it with no alt).
I went to each rocker one at a time. I loosened the poly lock with a wrench until it was really loose (finger loose) and the rocker was clanking around. Then I tightened the poly lock back down with my fingers, yes fingers until it stopped turning freely (this should be right as the poly lock seats against the rocker) this will also be the exact moment you hit zero lash. Then I added an additional 1/2 turn with a wrench. I installed the allen set screw and tigntened it down. Then I gave the poly lock a sinch with a wrench to make sure the whole thing was locked in place. I repeated this process with all of the rockers. You will make a bit of a oily mess, but it's not a big deal. You will get the hang of it and adjusting roller rockers will be easy.
I then put the covers and alt back and and proceded to deposit rubber down a local street...
Thanks for the help -Chris Trending Topics
Thanks for the help -ChrisThe Best V8 Stories One Small Block at Time
I use method 1 (you pretty much have to for initial setup) and have not touched my valves in years.
