WTF do I do now?!!!
Old Jul 9, 2009 | 08:52 PM
Nads06111's Avatar
Default WTF do I do now?!!!
I was changing my valve springs and when I attempted to pull the valve stem seal out, the whole sleeve cam with it. Can I hammer it back in?
Old Jul 9, 2009 | 09:25 PM
Tbird232ci's Avatar
I don't have any advice, but that's the first time I've ever seen that!
Old Jul 9, 2009 | 09:27 PM
toby's Avatar
i would definetly pull the head and take it to a machine shop for repairs. if it comes out with the engine running it could cause serious damage.
Old Jul 9, 2009 | 09:45 PM
robsquikz28's Avatar
put it this way I have heard of people just hammering it back in ever so gently and it being perfect and Then I have heard the horror stories of them doing that and **** just going kaaabbooooommmm
So its up to you what you would like to do, im sure others will post advice and if you google and research you might find what your looking for
Old Jul 9, 2009 | 09:47 PM
LT1's Avatar
LT1
Valve guides not suppose to come out like that. My first time seeing this too.
Old Jul 9, 2009 | 10:24 PM
96blackz28's Avatar
Aww man that sucks, good luck
Old Jul 9, 2009 | 10:46 PM
Z-RATED94's Avatar
Sorry to hear about your bad luck. Now would be a good time to pull the heads and have some porting done. There might be a way to get it back in securely, I don't know, but will you take the chance that another might do the same thing?
Old Jul 9, 2009 | 10:51 PM
Nads06111's Avatar
This sucks. Hopefully someone will chime in who has tapped it in and had success.
Old Jul 9, 2009 | 10:55 PM
Nads06111's Avatar
i did 9, and this is the only one so far that pulled out.
Old Jul 9, 2009 | 11:09 PM
Z-RATED94's Avatar
So what does that mean? Just because they stayed in with you pulling on them is not exactly a foolproof test now, is it?
Old Jul 10, 2009 | 04:24 AM
RamAir95TA's Avatar
There's no way in hell I'd try to pound that back in. Take off the head and have it fixed.
Old Jul 10, 2009 | 10:18 AM
chavez885's Avatar
What the hell? Machine shop, now, go.
Old Jul 10, 2009 | 10:42 AM
SS RRR's Avatar
Village Troll
Yes, guides just don't pull out like that unless there is a problem. In order to pull guides normally the head has to be heated and they still have to be hammered out.
As suggested your ONLY wise option is to go to a machine shop. It would not be surprising if your other guides may have issues. More than likely they all need to be replaced.
Old Jul 11, 2009 | 01:14 AM
SlideRight's Avatar
go get yourself some dry ice and cool that guide down for a bit and see if it will ease back into place..*shrug*
